Which O2 sim works?
Old May 10, 2005 | 07:18 PM
ABK's Avatar
ABK
Default Which O2 sim works?
I've searched all over this board, and everywhere I read somebody says that that design o2 sim doesn't work. Can anybody tell me which one works and which one doesn't?
Old May 10, 2005 | 07:22 PM
civictildeath's Avatar
Default Re: Which O2 sim works? (ABK)
o2 sim install thread in my sig below has link to buy one. has been working for me so far
Old May 10, 2005 | 07:25 PM
ABK's Avatar
ABK
Default Re: Which O2 sim works? (civictildeath)
do you happen to know what's inside of it? I would figure it would be like a 25 ohm resistor or some **** like that so that 12v would be trasfered to constant .46v something close enough to fool the computer that cat is working fine.
Old May 10, 2005 | 07:39 PM
i dont have the slighest clue as to what is in it. i paid $29.99 with shipping and installed it and it works. i really dont want to open it and screw it up. the site for it may have some info on it but not sure
Old May 11, 2005 | 04:04 AM
EE_Chris's Avatar
Doesn't work that way...
During cruising conditions, the rear O2 generally hangs around .6-.8v (indicating a rich condition, or rather, a condition lacking air which means the catalytic converter seems to be using the air to do its job).
On a decel, with throttle closed, both O2's go dead lean - so how would your resistor trick work there?
Look at the ECG Simulator and the sensors that it taps into - the rear O2 signal needs to show change based on other sensor inputs.
Old May 11, 2005 | 05:44 AM
IHateJDM's Avatar
Default Re: Which O2 sim works? (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">On a decel, with throttle closed, both O2's go dead lean - so how would your resistor trick work there?
Look at the ECG Simulator and the sensors that it taps into - the rear O2 signal needs to show change based on other sensor inputs.</TD></TR></TABLE>
A friend has this prob right now, and the o2 sim didn't work at all. I heard it works fine on obd1 cars, if you want to replace your only o2. OBD2 is nothing but problems from what i've read.
Old May 11, 2005 | 06:46 AM
urnotfast's Avatar
ive got a 02 sim from kteller and it works flawlessly on my 99 si. came with great instructions and installed pretty easily. definitely a very good one to use.
peace
eric
zirac50
May 27, 2008 10:06 AM
AGENT 99
Mar 5, 2006 09:46 AM
TalkTonight
Jan 28, 2006 05:08 PM
98dxhatch
Nov 8, 2003 11:12 PM
genop
Sep 12, 2002 10:09 AM
