oil temp gauge
Old May 10, 2005 | 06:18 PM
superchargedex's Avatar
Default oil temp gauge
i am getting ready to install a oil temp gauge in my 2000 civic whats the best place too put it
Old May 10, 2005 | 06:33 PM
SOHC4life 96's Avatar
Default Re: oil temp gauge (superchargedex)
If it's mechanical, back in the box with a "return to sender" stamp on it. (kidding)
Put it wherever you want so that you can stills see it without taking your eyes completely off the road.
Old May 11, 2005 | 05:46 AM
Default Re: oil temp gauge (SOHC4life 96)
no i mean the the best place to install the sending unit
Old May 11, 2005 | 06:10 AM
JDMlyfestyle's Avatar
off the oil sending unit on the back of the block. put a T in and connect the stock sensor and the gauge.
Old May 16, 2005 | 06:46 PM
Jago's Avatar
install it in the oil pan that is the only correct way. Coming off the sending unit will
give incorrect temp readings
Old May 16, 2005 | 06:50 PM
ralphie14's Avatar
Default Re: oil temp gauge (Jago)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jago &raquo;</TD></TR><TR><TD CLASS="quote">install it in the oil pan that is the only correct way. Coming off the sending unit will
give incorrect temp readings</TD></TR></TABLE>
Yeah oil pan is the best place.
Old May 17, 2005 | 08:03 AM
civic-4-ges's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">If it's mechanical, back in the box with a "return to sender" stamp on it. (kidding) </TD></TR></TABLE>
Not trying to be an ***, but why?
I am trying to get the pros/cons of each, other than the oil line in the engine bay!
Old May 17, 2005 | 09:22 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: oil temp gauge (civic-4-ges)
mechanical guages are best. regardless of what people say, there is NO oil being plumbed into the cabin with an oil temp guage. i have run mechanical for years, and will continue to do so.
Old May 17, 2005 | 05:05 PM
Default Re: oil temp gauge (Rodney)
Oops...mis read
Thought it was oil pressure!
Crippledduck51
Sep 12, 2007 09:19 PM
GUILOTINE
Feb 12, 2005 06:52 AM
GUILOTINE
Feb 3, 2005 04:14 PM
Zorro
Feb 13, 2003 05:44 AM
SPOON_BeIgHtEeNsEe
Mar 4, 2002 05:24 PM
