Polishing Valve Cover
Old May 10, 2005 | 05:17 PM
DFW's Avatar
DFW
Default Polishing Valve Cover
Is this what it's suppose to look like after I spray the Aircraft Remover on?
The stuff
I highest grit of sandpaper that I found in my garage had was 320
After some sanding and one small coat of polish only on one part of the valve cover...
Also if I put more polish on does it get shinnier?
Old May 10, 2005 | 05:37 PM
DFW's Avatar
DFW
bump
Old May 10, 2005 | 05:39 PM
Blanket Jackson's Avatar
Get you a buffer wheel and a dremel, it is gonna be a pain in the *** if ya don't have one. A drill with an adapter might work also.
Old May 10, 2005 | 05:40 PM
opiumdaze's Avatar
Default Re: (SlowSpyder)
use thinner sandpaper then polish.. itll get really shiny
Old May 10, 2005 | 05:41 PM
opiumdaze's Avatar
Default Re: (opiumdaze)
2000 grit or something close to that
Old May 10, 2005 | 05:54 PM
graveltravel's Avatar
man, just sandblast it! it would be much easier that way!
Old May 10, 2005 | 05:59 PM
markwitdada9
Guest
Posts: n/a
Old May 10, 2005 | 06:02 PM
DFW's Avatar
DFW
Default Re: (graveltravel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze &raquo;</TD></TR><TR><TD CLASS="quote">use thinner sandpaper then polish.. itll get really shiny</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markwitdada9 &raquo;</TD></TR><TR><TD CLASS="quote"> 2000 grit or something close to that </TD></TR></TABLE>
Oh ite, the finest I had was 320 . What do you think about starting off with 400 and work my way up to about 1000. Maybe 2000 or somewhere in between. How much does it cost? Would just Home Depot or something have it?
Old May 10, 2005 | 06:22 PM
DFW's Avatar
DFW
Default Re: (DFW)
Old May 10, 2005 | 06:25 PM
opiumdaze's Avatar
Default Re: (DFW)
well smoothen it out by the 320 grit then use around 800 grit or something to take out the small lines and what not then use 1500 or 2000 grit or pick.. it will be like a mirror
Old May 10, 2005 | 06:27 PM
plusONE jboy's Avatar
yeah you have to go in stages.. starting out with roughest grit all the way down to the finest grit.. then wetsand.. then polish
Old May 10, 2005 | 06:30 PM
or you could just simply sand blast it! haha
Old May 10, 2005 | 06:31 PM
DFW's Avatar
DFW
Default Re: (j boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opiumdaze &raquo;</TD></TR><TR><TD CLASS="quote">well smoothen it out by the 320 grit then use around 800 grit or something to take out the small lines and what not then use 1500 or 2000 grit or pick.. it will be like a mirror</TD></TR></TABLE>
Sounds like a good idea
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j boy &raquo;</TD></TR><TR><TD CLASS="quote">yeah you have to go in stages.. starting out with roughest grit all the way down to the finest grit.. then wetsand.. then polish </TD></TR></TABLE>
Noobish question, how do you wetsand, or what is it for that matter?
Old May 10, 2005 | 06:32 PM
DFW's Avatar
DFW
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by graveltravel &raquo;</TD></TR><TR><TD CLASS="quote">or you could just simply sand blast it! haha</TD></TR></TABLE>
nahhh, DIY things are fun
Old May 10, 2005 | 07:03 PM
DFW's Avatar
DFW
up
Old May 10, 2005 | 07:59 PM
DFW's Avatar
DFW
Default Re: (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">up</TD></TR></TABLE>
Old May 10, 2005 | 08:16 PM
Powered By Garrett's Avatar
Wetsanding is where you get the sand paper wet. Just get a bucket of room-temp water (so you dont freeze your hand) and soak the sand paper in there so it get nice and wet, sand with it wet and keep the sand paper wet (keep dipping it in the water). hope this helps, good luck with the project. Oh, and sand paper is cheap, you can get it just about anywhere, yes, Home Depot should have sand paper.
Old May 10, 2005 | 08:29 PM
DFW's Avatar
DFW
Default Re: (EGtenchu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGtenchu &raquo;</TD></TR><TR><TD CLASS="quote">Wetsanding is where you get the sand paper wet. Just get a bucket of room-temp water (so you dont freeze your hand) and soak the sand paper in there so it get nice and wet, sand with it wet and keep the sand paper wet (keep dipping it in the water). hope this helps, good luck with the project. Oh, and sand paper is cheap, you can get it just about anywhere, yes, Home Depot should have sand paper. </TD></TR></TABLE>
Sweet, thanks for the help.
Hopefully it will turn out blinging
Old May 10, 2005 | 08:35 PM
DFW's Avatar
DFW
Default Re: (DFW)
BTW, B18a valve covers freakin suck. Sooo many little spots that are hard as hell to sand down Oh well, just a practice valve cover anyways
Old May 10, 2005 | 09:21 PM
budget's Avatar
Default Re: Polishing Valve Cover (DFW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">BTW, B18a valve covers freakin suck. Sooo many little spots that are hard as hell to sand down Oh well, just a practice valve cover anyways </TD></TR></TABLE>
Yeah seems like it
bump for you
Old May 10, 2005 | 09:27 PM
Dforce's Avatar
That's what she said!
Old May 10, 2005 | 09:45 PM
DFW's Avatar
DFW
Default Re: Polishing Valve Cover (Dforce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dforce &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Old May 10, 2005 | 10:05 PM
harlen's Avatar
post pix when done =D
Old May 10, 2005 | 10:21 PM
DFW's Avatar
DFW
Default Re: (harlen)
bump before bed
Old May 11, 2005 | 07:26 AM
john d
Guest
Posts: n/a
Default Re: (DFW)
where can you get it sand blasted? how much is it ussually
