Are these CRX Fog Light Brackets?? I Need Some Help and Advice....(Kinda Long)
Old May 10, 2005 | 03:24 PM
JesseCRX's Avatar
Default Are these CRX Fog Light Brackets?? I Need Some Help and Advice....(Kinda Long)
I came across these on ebay and the guy says that they are for a 90-91 CRX so I bid and won them but as I was looking around some more I came across some other sets of fogs on ebay and they brackets don't look like CRX brackets at all.
Here is the auction
http://cgi.ebay.com/ebaymotors...35948
His item description: THIS IS AN AUCTION FOR SET OF TWO (LEFT AND RIGHT) FOG LIGHT BRACKETS FOR A 1990/1991 CRX. I DON'T KNOW IF THESE WILL WORK ON 88/89 CRXS OR NOT. THEY ARE NEW IN THE BAG STILL, NEVER BEEN INSTALLED.
I BOUGHT THEM TO REPLACE THE RUSTY FOG BRACKETS ON A SET I GOT ON EBAY A WHILE BACK, BUT I CHANGED MY MIND ABOUT USING FOGS ON MY PROJECT, SO I'M SELLING THEM.
A MUST-HAVE FOR ANYONE WITH RUSTY FOGLIGHT MOUNTS, OR ANYONE WHO BOUGHT CIVIC FOGS AND NEED TO INSTALL THEM ON A CRX!
Here is a pic of the brackets he is selling
I emailed him and this is EXACTLY what I wrote...
Hey man, I just put did the buy it now option on your brackets and I
was looking a bit more closely at them.....are you certain that these
are for a CRX at all??
I was looking at this other auction and the brackets you have don't
look like them at all.
Here is the auction
http://cgi.ebay.com/ebaymotors...33709
and here are the direct links to the old CRX brackets...
I just want to make sure I am buying the right items. Get back to me asap....
Thanks!
His response....
"They are in a bag, with a part number for a CRX. The parts are engraved with
SH2 (Honda parts-code for CRX) directly from Honda. They are for a CRX.
If they are not the brackets that you need/want, there is not much I can do
for you. You should always do your research PRIOR to bidding/buying.
Thank you,"
I then responded....
"What are the exact part numbers? If they are what you say they are
then I'll send the money. If they are not the brackets for a CRX then
your auction is not describing the items correctly. I am going to
research this on several CRX forums just to make sure.
Thanks."
He's coming across as rude......I just wanna make sure I am getting the right parts for my fog setup.
Any advice??
Thanks fellas
JC
Old May 10, 2005 | 04:48 PM
b16_madman's Avatar
Default Re: Are these CRX Fog Light Brackets?? I Need Some Help and Advice....(Kinda Long) (JesseCRX)
my fog brackets came from a ef9 or 8 and they look unlike either of those, so there's a lot of varaitions
the ones you last pictured are the best appearingly b/c you can adjust them a bunch
i don't know about the first ones, don't look like their shape is fitting for anything, but it may be either for a older crx, or i'm just wrong
Old May 10, 2005 | 04:52 PM
stealth civic's Avatar
Default Re: Are these CRX Fog Light Brackets?? I Need Some Help and Advice....(Kinda Long) (B16_madman)
The ones you bought look just like the ones I have on my crx, which are OEM USDM fog lights. The ones your pictures are the jdm fogs.
Old May 10, 2005 | 05:10 PM
JesseCRX's Avatar
Default Re: Are these CRX Fog Light Brackets?? I Need Some Help and Advice....(Kinda Long) (stealth civic)
Thanks stealth civic.
I found that foglight install manual online and sure enough the brackets do look just like them.
Kinda pricey but I have no patience...
static-x
Jan 16, 2009 06:04 AM
Rob.
Apr 20, 2006 07:03 PM
schwanginpt
13
Nov 24, 2003 02:22 AM
jovial111
Sep 26, 2003 09:27 PM
