'95 Accord Airbag Brain
So the SRS light has been on for sometime. Finally took the car to Honda, and they found out that the airbag "brain" is bad, so the airbags WILL NOT deploy in an accident. They said the part is about $400.00 and labor 2 hours=$150.00 SCREW THAT I should be able to do it myself. Anyone had this problem. Dealer also said i can pull the part from a junkyard, as long as the airbags did not deploy. Anyone know where the "brain" for the airbags is on this car. '95 LX accord sedan.
Thanks
Thanks
control unit is located in frt center of car below heater under dash ... i think there are 4 bolts that hold it in place you have to get 2 from each side you cannot get to rt side bolts if you removing left sides
FIXED!!! I pulled a unit out of a 95 Lx in the junk yard, paid like 30$ for it, tho it looked kind of different, but all the bolts lined up....WALLLAH, no more SRS light!! thanks for the advice, tomaro doin all the fluids, and 2 accessory belts
r3000
Audio / Security / Video
Dec 15, 2004 01:05 PM
