Skunk2 valve springs and retainers? how much?!!
Old Feb 4, 2002 | 09:18 AM
Malice's Avatar
New User
Default Skunk2 valve springs and retainers? how much?!!
i cant find any sites that have prices for these. how much do they go for? any brand is fine. im planning on raising my limiter to about 8500. Can anyone recommened on who i should go to...maybe a hook up price?
Ken- who thought it would be nice to work in the hook up part.
TIA
Old Feb 4, 2002 | 09:22 AM
sgT's Avatar
sgT
Default Re: Skunk2 valve springs and retainers? how much?!! (MaliceGSR)
what cams?
Old Feb 4, 2002 | 09:26 AM
BoM's Avatar
BoM
Default Re: Skunk2 valve springs and retainers? how much?!! (sgT)
what cams?
to add, sometimes you dont' need certain valvesprings and retainers.
some cheaper valvesprings/retainers can withstand the lift and high rpms
of certain cams
Old Feb 4, 2002 | 09:41 AM
Malice's Avatar
New User
I have Skunk2 Stage 1 cams.
Old Feb 4, 2002 | 09:53 AM
sgT's Avatar
sgT
I would get itr intake springs for both intake and exhaust sides along with
some ti retainers.
Those should be fine for you
Old Feb 4, 2002 | 10:02 AM
Mike K's Avatar
ditto. run all yellows. yellow inners too.
Old Feb 4, 2002 | 10:14 AM
Malice's Avatar
New User
thanks...how much do they go for?
[Modified by MaliceGSR, 7:16 PM 2/4/2002]
Old Feb 4, 2002 | 10:23 AM
Austin's Avatar
some ti retainers.
Steve...would you recommend this setup on a car with stock itr cams and Ti retainers, or are the stock springs fine?
Austin
Old Feb 4, 2002 | 10:25 AM
sgT's Avatar
sgT
Default Re: Skunk2 valve springs and retainers? how much?!! (Austin)
stock springs + stock R cams + ti retainers good to 9500
Old Feb 4, 2002 | 10:29 AM
Austin's Avatar
Thanks Steve, just needed the clarification, as that's what my future holds.
Austin
Old Feb 4, 2002 | 10:34 AM
Chris's Avatar
Yea, but will stock Cams make power up that high?????
Old Feb 4, 2002 | 10:36 AM
Austin's Avatar
Default Re: Skunk2 valve springs and retainers? how much?!! (Chris)
Hey...if they're already out, might as well replace them if the other are better mentality being used. Most likely it will be to around 9100 rev limiter, all depends upon what the curve looks like and what Lawrence thinks.
Austin
Old Feb 4, 2002 | 10:44 AM
Malice's Avatar
New User
once again....how much $$$??!!!!
Old Feb 4, 2002 | 10:56 AM
Chris's Avatar
I was just curious..as I do not know those things.
Old Feb 4, 2002 | 11:03 AM
BoostinDC2's Avatar
but with the skunk srpings i thought u had to change out the spring seat to there spring seat?
Old Feb 4, 2002 | 11:34 AM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
Default Re: Skunk2 valve springs and retainers? how much?!! (Mike K)
Hey Mike, remember I asked you... on the inner springs, the yellow intake springs seems to be *softer* than the exhaust side. But this is based on my fingers, not a spring tester. I thought you agreed? No?
Skunk2 valvesprings are retainers are $385 shipped from me.
Old Feb 4, 2002 | 01:07 PM
BABY NSX's Avatar
Default Re: Skunk2 valve springs and retainers? how much?!! (frank@b16a.com)
Since the intake and exhaust valve weight the same the required spring rates for the two are going to be determined by the cam profile for each.
Now the exhaust cam is almost always milder then the intake cam (as is the case with the stock cams) so it stands to reason that the exhaust springs should be softer then the intake springs (as a set).
In fact this can clearly be proven with the stock springs because the exhaust springs on the R are the same springs used on the GSR intake, also the GSR uses a single spring on the exhaust. Obviously the stock intake spring sets are stiffer then the exhaust. By how much? Don't know...
preludedriva
Sep 8, 2007 10:57 PM
austrian type-R
Jul 20, 2003 02:26 PM
Aaron M
May 8, 2003 04:41 PM
Mr Hybrid
Mar 16, 2003 12:04 PM
