Suspension & Brakes Theory, alignment, spring rates....
replacing rear subframe
Old May 10, 2005 | 02:44 PM
philosofy1's Avatar
Default replacing rear subframe
would i be able to install a type r rear subframe on a eg ( i think i can, just making sure.)?
how hard is it to DIY and would i have a problem w/ tear outs when i had a rear sway bar (preferably st sway bar).
dont burn me to bad, just tring to set up my rear suspension right, i just want to do the job once.
Old May 10, 2005 | 03:59 PM
nonsense's Avatar
Default Re: replacing rear subframe (philosofy1)
If you can weld it probably won't be too hard. You have to drill out all of the original welds, then pop the old one off and weld up the new one. It has to be 100% perfect though, or it can really screw your alignment up.
Why are you going ot do this if you haven't already torn out your subframe? I'd look into the ASR reinforcement and sway bar. (http://www.a-spec-racing.com)
ekinshuya
May 31, 2009 07:36 AM
shorejdm5
12
Dec 8, 2007 09:51 PM
DarkBB4
Jun 6, 2006 02:56 PM
Cuong-nutz
Suspension & Brakes
Aug 8, 2005 03:45 PM
mr2td
Oct 14, 2002 06:00 PM
