civic Ex sway bar in DX?
if your taking it exactly from one car to another then you should be using the same brackets, bolts, etc.
given that you already have lower control arms to take the sway bar.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrage »</TD></TR><TR><TD CLASS="quote">So it will bolt right in to my lower control arm? I have the stock suspension with ground controls and AGX's..</TD></TR></TABLE>
As long as you have #13 in the pic with the nut and the rubber thingy, thats what connects the bar to the LCA:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4d00r »</TD></TR><TR><TD CLASS="quote">the LCA's from the EX and DX are the same. Only the Si is different because the Si bar is thicker and connects to the LCA</TD></TR></TABLE> Thsi is false. The DX LCA does not have mounts for a swaybar. The EX obviously does and the Si is different because it is stamped steel vs cast. If you want to put the ex bar on you will need to get the lower control arms d bushings, brackets, bar
and the endlinks.
and the endlinks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetrage »</TD></TR><TR><TD CLASS="quote">so what about the aftermarket sway bars for the DX? They dont require you to install EX LCAs.... Do they include a bracket or something?</TD></TR></TABLE>
They include brackets that clamp onto your existing LCAs (from what I've seen in the past)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cruizinmax »</TD></TR><TR><TD CLASS="quote">I just said that. </TD></TR></TABLE>
Sorry, I didn't mean to steal your thunder. I just read the question, and quickly posted my response...
It doesn't work that way. The aftermarket bar & end-links are designed to matched those brackets. They could connect to the LCA in totaly different places that won't allow an OEM bar to work. In fact, some OEM bars only work w/ specific LCAs & end-links...
hondacurious
Jul 25, 2010 08:49 PM
Hemix
Dec 6, 2006 04:17 PM
dek1mfk
Jul 19, 2006 11:02 AM
