Shift linkage pin
Old May 10, 2005 | 11:54 AM
mark7901's Avatar
Default Shift linkage pin
Anyone know the easiest way to remove the "bitch" pin from a 5th gen civic> (z6) Is their a particular size punch you need?
Old May 10, 2005 | 12:00 PM
hatchish's Avatar
bring 1 of your friends over that knows what there doing give them a beer and they will get it out or just fit a punch in there and beat the mother ****** out!thats what i did
Old May 10, 2005 | 12:01 PM
EJ1 wilcox's Avatar
Default Re: (hatchish)
8mm or 5/16" non-tappered roll-pin punch...
Old May 10, 2005 | 12:11 PM
snatch's Avatar
Default Re: (EJ1 wilcox)
And just when you think it won't come out, keep hammering.
Old May 16, 2005 | 05:09 PM
Imprezor's Avatar
Default Re: (******)
lol reminds me good stuff
Old May 16, 2005 | 05:12 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (Imprezor)
ahhhh teh beotchhhh pin... ahhh memories use a non-tapered 8mm punch pound it like how you would pound your gf
Old May 16, 2005 | 05:23 PM
itsJDMyo's Avatar
Default Re: (BrokeAssPinoy)
does anyone have a pic. of what this 8mm pin looks like? i can't seem to find it
Old May 16, 2005 | 05:29 PM
Default Re: (itsJDMyo)
non-tapered of course brought to you by sears " "Good Life, Great Price"
Old May 16, 2005 | 05:45 PM
Calvinator's Avatar
1/4 punch works for me
Old May 16, 2005 | 05:47 PM
SkRiBLaH's Avatar
Default Re: (xtremeazian)
no need to remove pin.
just remove the shift linkage.
Old May 16, 2005 | 05:51 PM
KtHaNxBai's Avatar
Default Re: (SkRiBLaH)
heat it up, and beat the crap outta it.
Old May 16, 2005 | 05:58 PM
Hybrid96EK's Avatar
Default Re: (galaxykid70)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by galaxykid70 &raquo;</TD></TR><TR><TD CLASS="quote">heat it up, and beat the crap outta it.</TD></TR></TABLE>
No. Use an air hammer with a 7mm punch tool in it and be done....quickly.
Old May 19, 2005 | 07:58 AM
mark7901's Avatar
"just remove the shift linkage."
lol, thats classic.....sorry, dont feel like bending the shift linkage when removing the engine.
The puch worked like a charm! Thanks all!
Old May 19, 2005 | 08:09 AM
turboxsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian &raquo;</TD></TR><TR><TD CLASS="quote">1/4 punch works for me</TD></TR></TABLE>
, only takes a few minutes of beating the **** with a hammer.
Old May 19, 2005 | 08:28 AM
JDM EJ1 95's Avatar
use your bolt from your ac compressor... take one of the ones out that holds it to the bracket.. they work wonders
Old May 19, 2005 | 08:29 AM
The Internet Tough Guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">no need to remove pin.
just remove the shift linkage.</TD></TR></TABLE>
that is much more trouble than just pounding that pin out. it's not that difficult just get the 8mm punch and a BFH and give it hell.
Old May 19, 2005 | 08:36 AM
Crasian's Avatar
removing the shift linkage out is pretty easy i find, just undo the two bolts that hold it in, take off your shiftknob and pull it down.
but if u stillw anna go the pin route, when all else fails, get a bigger hammer
Old May 19, 2005 | 09:10 AM
Deemeetree's Avatar
Electrician
Removing the linkage isn't that hard at all. I've never tried to remove the bitch pin, but from what everyone says, I rather pull the linkage.
Old May 19, 2005 | 09:17 AM
mark7901's Avatar
Default Re: (Dimitri_EG8 a.k.a. Dimi)
^^^Yeah, but when you try to remove the engine, you'll have to jack the car up way too far so you dont bend the linkage.
Old May 19, 2005 | 10:16 AM
JDM EJ1 95's Avatar
not if you drop the enigne from the bottom... its easier going from the bottom anyways... i never knew someone who went in from the top
Old May 19, 2005 | 11:57 AM
itsJDMyo's Avatar
Default Re: (JDM EJ1 95)
i did, when i swapped in my ls motor
Old May 19, 2005 | 12:15 PM
deeksmooth's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo &raquo;</TD></TR><TR><TD CLASS="quote">i did, when i swapped in my ls motor</TD></TR></TABLE>
as did i when i swapped my b18 into my old Sol...
Old May 19, 2005 | 12:23 PM
JDM EJ1 95's Avatar
i dont know you guys... and anyways its just a hassle... im a backdoor man
Old May 19, 2005 | 12:41 PM
SRCivic97's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM EJ1 95 &raquo;</TD></TR><TR><TD CLASS="quote"> im a backdoor man</TD></TR></TABLE>
I would never announce that. ever.
On a side note: Buy the punch kit - you'll have plenty of other opportunities to put it to good use.
Old May 19, 2005 | 12:52 PM
Deemeetree's Avatar
Electrician
Are you seriously trying to get yourself in trouble here? I mean, come on, self-ownage.
