Manual Door lock Swap
Old May 10, 2005 | 10:21 AM
VegasEFHB's Avatar
Default Manual Door lock Swap
I am looking into purchasing a new set of doors for my 88 std Hatch soon and I need to know if there is a way to swap over the locks ONLY, not the handles and locks, to the new Si doors with the painted handles. I want to be able to maintain the same key that operates the hatch and ignition and make the doors use the same as well. Does anybody have any experience with this?
Old May 10, 2005 | 11:32 AM
NikoZai's Avatar
Default Re: Manual Door lock Swap (VegasEFHB)
yeah, you can easily take apart the lock mechinism in the door
http://www.norcalcrx.org/library/
download the workshop manual, i do believe there is a page detailing the process.
basically, remove interior door panel, unscrew door handle, pop off the lock rod and opening rod, remove handle, pop off C clip, remove lock.
Old May 10, 2005 | 12:07 PM
VegasEFHB's Avatar
Default Re: Manual Door lock Swap (NikoZai)
Thanks man! appreciate the help
haydeon
Feb 25, 2014 03:56 PM
black94boost
Nov 3, 2006 09:57 AM
RedKroovy
Nov 3, 2005 12:14 PM
sleepingcivic90
Jan 16, 2005 05:52 PM
