Old Mar 25, 2015, 10:51 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Starter replacement 91 Accord
Old May 10, 2005 | 09:51 AM
kabuki's Avatar
Default Starter replacement 91 Accord
I have a 91 Accord LX manual trans that needs a new starter. I am getting tired of having my 9 year old tap the starter to get it going. Has anyone here replaced one and how difficult is it? I am considering paying to have it done, but I will do it myself if it's not too hard. I've done other things like change oil, replace brake pads, replace head gasket, etc.
Old May 10, 2005 | 10:17 AM
deserthonda's Avatar
not very hard at all if you are mechanically inclined,, disconnect battry cable to avoid short, remove main power wire from starter 12mm nut, unplug solenoid wire, 2 bolts hold the starter remove those it will come out use a factory part if you can ,, or you might have to do the work all over again within the year due to exccessive noise when starting seen a few non factory have that problem
Old May 10, 2005 | 10:45 AM
Monkey Fing a Coconut's Avatar
Default Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">not very hard at all if you are mechanically inclined,, disconnect battry cable to avoid short, remove main power wire from starter 12mm nut, unplug solenoid wire, 2 bolts hold the starter remove those it will come out use a factory part if you can ,, or you might have to do the work all over again within the year due to exccessive noise when starting seen a few non factory have that problem </TD></TR></TABLE>
do u reply to every post??? damn...anyways, like he said, i have an autozone starter on my h22 that has worked fine for the last two years, lifetime warranty as well
Old May 10, 2005 | 11:46 AM
yo twisted if i can help someone then i will reply ,,isnt' it what this is all about trying to help one another???
Old May 10, 2005 | 07:47 PM
hondadude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">isnt' it what this is all about trying to help one another???</TD></TR></TABLE>
Sad to say but at least 1/2 the people here have the single minded goal to flame, slam, and goad any chance they get.
whitefloor
Apr 19, 2016 12:36 AM
dannyrok
Aug 20, 2013 07:17 PM
killerkali420
Mar 30, 2011 04:29 PM
allsho
Aug 29, 2007 01:52 PM
tlovaj
Aug 23, 2007 04:17 PM
