Whats the differenceL: 90 Civic STD/DX Engines?
Old May 10, 2005 | 09:18 AM
vtec25's Avatar
Default Whats the differenceL: 90 Civic STD/DX Engines?
so far all i can find is that its just the head. if this is so can i just change the head for one from a DX and gain those extra 20hp to the flywheel? Also if it is so can i use a newer head like from a 92+? And would i have to use the timing belt from the new head or can i keep the old one?
Also are the STD and DX ecu the same?
Old May 10, 2005 | 09:30 AM
FalkenSiR's Avatar
Default Re: Whats the differenceL: 90 Civic STD/DX Engines? (vtec25)
The difference between these engines is the cam- plain and simple. STD cam is the shittiest cam you will find in any car. It makes its peak power in the low end which is good for fuel economy and to get around town. Hey, just look at the specs, look at where they make their power at. That alone generally gives you a pretty good idea about the cam.
The DX cam makes slightly higher rpm power, like the si, but still has lower lift and still is a lil bit of an economy cam compared to the Si. You will see the most gains with an Si cam or even better with a ZC cam, but you have to use an adj cam gear as you will be off a tooth or something like that.
Old May 10, 2005 | 10:16 AM
logicdc's Avatar
Default Re: Whats the differenceL: 90 Civic STD/DX Engines? (fast88std)
you will have to change over to a dx ecu also.
Old May 10, 2005 | 10:47 AM
mahatma's Avatar
Default Re: Whats the differenceL: 90 Civic STD/DX Engines? (logicdc)
Doesn't the Std have some restrictor in the intake/IM also?
Old May 10, 2005 | 11:19 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: Whats the differenceL: 90 Civic STD/DX Engines? (mahatma)
slow and slower....
as said before its that cam and yea lil restrictor in it i took it out and it added .01 mental horse power it really didn't do anything at all good or bad.
Old May 10, 2005 | 02:51 PM
FalkenSiR's Avatar
Default Re: Whats the differenceL: 90 Civic STD/DX Engines? (Ace$nyper)
People swear it's a restrictor, its the VACCUM ADVANCE UNIT!!!
Old May 16, 2005 | 03:18 PM
smoke07018's Avatar
nothing is difference with the engines. but the differences is the features
crex23
18
May 13, 2005 07:49 PM
MaaseyRacer
Mar 12, 2004 01:38 AM
1CiViC1
Jul 17, 2003 01:07 AM
OldGeezer
10
Dec 16, 2001 10:05 PM
