B16 HELPPPPPPP
im guessing this seal sits in that little lip on the intermediate shaft correct? i really hope this is the problem. how hard is it to replace that seal? also do u think its safe to drive it without full tranny oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-treme »</TD></TR><TR><TD CLASS="quote">im guessing this seal sits in that little lip on the intermediate shaft correct? i really hope this is the problem. how hard is it to replace that seal? also do u think its safe to drive it without full tranny oil? </TD></TR></TABLE>
It's not hard to replace the seal. You gotta pull the axle and intermediate shaft out. I don't suggest you drive for very long before replacing the seal. Use your best judgement. How much has leaked out?
even if the seal is in there, it still might be bad. look for cracks in the rubber. the spring popped out of mine, and it still looked good, but leaked. a few bucks at the dealer, and took only a few minutes to install.
my motor didnt come with the intermediate shaft, i had to buy new..... so the seal does go into that lip? cuz there definitly wasnt one in there when i slid it into place. if this is true, that explains y ALL my oil drained out of the tranny after like 10 min of driving. good thing i checked on everything after the maiden voyage....im picking up the seal tomarow, ill let u guys know what happens .thanks for all the help
ok i got that seal replaced, but now i cant get the castle nut back on the ball joint stud.....the threads got all messed up when i was seperating the ball joint. how do i fix the threads? or can i file the last 2 or 3 down cuz those are the only ones messed up? please help
caliskier
Apr 14, 2012 08:52 AM
oranginal
Aug 26, 2010 12:48 PM
philliedawg
Jul 20, 2008 05:35 AM
BOSS-REX
Nov 12, 2004 09:23 PM
