How Do You Replace Rotors on 90 Accord?
Old May 10, 2005 | 08:16 AM
toicy4ya's Avatar
Default How Do You Replace Rotors on 90 Accord?
Sup fellas,
I need to replace the front rotors on my 90 honda accord, Is this difficult? Can someone give me instructions on how to do this?
I see the rotors have four screws near the center, is that all there is to it?
Thanks
Old May 10, 2005 | 08:19 AM
mugen92acintls's Avatar
Default Re: How Do You Replace Rotors on 90 Accord? (toicy4ya)
its not as easy as a civic or an integra because you have to separate the front wheel bearings like an Acura vigor. This is not an easy thing to do and you have to have a slide hammer
Old May 10, 2005 | 08:43 AM
Myroslav's Avatar
I tried to do it on my 90 accord. After 4 hours of hammering, I ended up replacing the whole knuckle. Both sides. Good luck with the task. I would not try it once again without the good press.
Old May 10, 2005 | 10:11 AM
deserthonda's Avatar
woo hold on there you do not need to do anything with bearings,,,
remove center axle nut, remove caliper from mounting bolts and lay it to the side, remove lower ball joint nut, separate joint from knuckle , slide axle out of hub as a matter of facts take it out of car it will easily slide through the fork,, on the back side there are 4 bolts either 10mm 12 point or 12 mm 6 point, remove those 4 bolts, now if you are replacing rotors get a big hammer and hit on the rotors they will come out some time if they are rusted in it takes a few big hits,,anyho that will remove rotrand hub assembly once out of car remove the 4 14mm bolts that bolt up rotor to hub once those are off, take rotor out , make sure you use a good 6 point socket to remove the 14mm bolts , before you put it back together clean knockle surface where hub slides in ...any questions holler
Old May 10, 2005 | 10:27 AM
swisher_man's Avatar
Do yours have press on rotors? I do on my 1996 Coupe. They were a bitch to remove last week, I'd really get some powerful tools and someone with some know-how.
Old May 10, 2005 | 10:42 AM
Monkey Fing a Coconut's Avatar
Default Re: (deserthonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">woo hold on there you do not need to do anything with bearings,,,
remove center axle nut, remove caliper from mounting bolts and lay it to the side, remove lower ball joint nut, separate joint from knuckle , slide axle out of hub as a matter of facts take it out of car it will easily slide through the fork,, on the back side there are 4 bolts either 10mm 12 point or 12 mm 6 point, remove those 4 bolts, now if you are replacing rotors get a big hammer and hit on the rotors they will come out some time if they are rusted in it takes a few big hits,,anyho that will remove rotrand hub assembly once out of car remove the 4 14mm bolts that bolt up rotor to hub once those are off, take rotor out , make sure you use a good 6 point socket to remove the 14mm bolts , before you put it back together clean knockle surface where hub slides in ...any questions holler</TD></TR></TABLE>
Old May 10, 2005 | 10:48 AM
t0p_sh0tta's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">...remove center axle nut...</TD></TR></TABLE>
Much easier said then done without power tools.
Old May 10, 2005 | 02:22 PM
GET A 36MM SOCKET A BIG PRY BAR AND THE BIGGEST FRIEND YOU CAN FIND OR 2 TO PUT ALL THEIR WEIGHT ON PRY BAR ..MAKE SURE YOU UNSTAKE NUT FIRST WITH A LITTLE PUNCH AND HAMMER
duwa
Apr 22, 2009 12:27 PM
jpopvriens
Apr 25, 2007 05:49 PM
conker
Oct 1, 2006 04:10 AM
alexsaccord
Feb 8, 2006 08:24 AM
dwjgoblue
Sep 22, 2005 04:14 AM
