89 CRX Si LS Swap
Hi I'm swapping a B18 LS motor into my CRX and i was wondering if anybody knows a good guide on the internet to help me out. I know all the basics but a little more help couldn't hurt. I have new mounts, shift linkage and everything else i need, i just want something to refer too incase i **** up..
You've got something to refer to if/when you screw up; all the people on honda-tech at any given time. If you mess up, post your exact problem here and it'll probably be solved quickly. Of course... the "Hybrid" forum may be a better place to ask.
There is online swap guides everywhere. I do know that you need for a direct swap a pre-obd Ls B18A1, pre-obd ECU, transmission/clutch/flywheel, integra axles, integra brakes and hubs, custom mounts, shift linkages, and 90-93 integra clutch cable. Thats all I can think of off hand but that about sums it up considering you are using the pre-obd engine that will plug right into the existing wiring harness.
yes, if your CRX is a Hf or Si you can plug taht engine right into it with no wiring needed
nice!
If you have a DX, you'll need to go MPFI with it, see Rywire.com.
nice!If you have a DX, you'll need to go MPFI with it, see Rywire.com.
