high compression b20
Old May 10, 2005 | 02:36 AM
tagperformance's Avatar
Default high compression b20
Has anyone ever heard of a stock b20 with custom high compression pistons cylinder walls cracking due to the pressure? it'a a high compression n/a motor!.
Old May 10, 2005 | 12:58 PM
allm0t0rsir's Avatar
Default Re: high compression b20 (tagperformance)
How high?
Old May 10, 2005 | 01:10 PM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tagperformance &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone ever heard of a stock b20 with custom high compression pistons cylinder walls cracking due to the pressure? it'a a high compression n/a motor!. </TD></TR></TABLE>
yep, over and over. They won't hold.
Old May 10, 2005 | 05:27 PM
f@sth@tch89's Avatar
Default Re: high compression b20 (skunked)
whats the hihest compression you can run on stock b20 sleeves?
Old May 10, 2005 | 08:43 PM
i was gonna put in some 13:1.1 pistons
Old May 10, 2005 | 08:51 PM
T4eg's Avatar
we've ran 13:1 on stock b20 sleeves, then the motor went boost (9:1) with pt63 and cracked the cylinder walls. the motor going into my beater is 85mm b20 13:1 stock sleeves. As long as its tuned u shouldnt have a problem.
Power Rev Racing
May 4, 2005 02:00 PM
drastikchangez
Feb 18, 2005 11:39 PM
ILOVEGIRLS
Oct 11, 2001 08:54 PM
