90 CRX Idling weird
Old May 9, 2005 | 10:38 PM
niceguy12's Avatar
Default 90 CRX Idling weird
My 90 crx hf just started idling weird
It bounces between 1000 and 1025 rpm just goes up and down
then stops for a while and hangs at 1000 rpm
It seemed to start when I put in a new thermostat
Old May 9, 2005 | 11:43 PM
Rywire's Avatar
Default Re: 90 CRX Idling weird (niceguy12)
like I told ya earlier, start by properly bleedin the coolant.
Old May 10, 2005 | 12:10 AM
nelsmar's Avatar
Default Re: 90 CRX Idling weird (droppedcrxsi)
im not sure what droppedcrxsi was saying, but ide go with making sure your coolant is filled up, squeese the upper radiator hose if is somewhat stiff(as in there is fluid in it) your good, what did you remove when you did the thermostat? if it is not the coolant maybe you bumped something?
Old May 10, 2005 | 10:26 AM
niceguy12's Avatar
Default Re: 90 CRX Idling weird (nelsmar)
I get it on bleeding the coolant but you didn't say how
I figured it out I'm trying to do a flush before I refill
To flush
The Haynes manual says the engine should be completely cool and I will need to drain the engine block too. Doesn't really tell me where the engine block drain plug (for coolant )really is.
The coolant bottle says (to flush) I should just turn on the engine, turn on the heater and run water in the top while it drains out the bottom of the radiator for about ten minutes.
So I have two questions
Which is the best way to flush the way the coolant bottle says or the way Haynes says ?
Where is the drain plug for coolant in the engine block? 90 CRX HF
Thanks
Old May 10, 2005 | 11:00 PM
nelsmar's Avatar
I might be wrong, but i dont think there IS a drain on the block(ive never noticed one at least). try turning on heater(so coolant goes to the heater in the car) and open the drain valve on bottom of radiator(its usualy a white thing that looks like a buterfly unscrew it PARTIALY) just take it out a lil and flush it....... till the liquid coming out turns clear(ide just use water personaly... but maybe something else works better?)
Myabe thatl will help ya out, good luck man :D
Old May 11, 2005 | 08:26 AM
niceguy12's Avatar
OK
Thanks
Is it OK to run the engine while I flush? becuase Haynes says no and I dont know why
Modified by niceguy12 at 10:39 AM 5/11/2005
Old May 11, 2005 | 11:39 AM
nelsmar's Avatar
Default Re: (niceguy12)
eh i wouldnt run OUT of coolant... i was saying just let it drain slowly so that way you can always fill it faster than it drains. the engine pulls water from bottom of radiator, and pushes it back in through the top. if you were to drain too quikly engine wouldnt be able to get any fluid. just take your time, ide imagine 5-10 mins would work. i HAVE driven withought coolant for a few mins(dont try it it sucks... overheat to hell) didnt seem to damage much though(my coolant line busted free)
Old May 11, 2005 | 01:30 PM
CRXDrew's Avatar
make sure ur throttle cable isn't too tight. could account for high idle and fluctuation due to tps enrichment.
Old May 11, 2005 | 02:04 PM
Rywire's Avatar
Default Re: (CRXDrew)
There is a bleeder screw by the upper rad hose, crack it and get all the air out
xTimmyx
Feb 5, 2012 11:07 AM
PphamEK
Mar 16, 2009 12:43 PM
george34
May 7, 2006 07:09 AM
GoLowDrew
19
Jun 13, 2005 09:01 PM
R249
Jan 24, 2003 04:17 AM
