how to get rid of wheel hop
Old May 9, 2005 | 07:52 PM
del_orson's Avatar
Default how to get rid of wheel hop
Just boosted my del sol. Any way when i break loose in the high rpms, i get real bad wheel hop. Ive seen the front load bars that you can buy, just woundering if that will correct this problem?
Old May 9, 2005 | 07:57 PM
james111's Avatar
Default Re: how to get rid of wheel hop (del_orson)
first question is what tires u running?
low profile? if so theres ur answer.....usually the lowpros have such a thick sidewall it always will bounce even if u have freakin tein all around...
Old May 9, 2005 | 08:36 PM
salt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote">Just boosted my del sol. Any way when i break loose in the high rpms, i get real bad wheel hop. Ive seen the front load bars that you can buy, just woundering if that will correct this problem?</TD></TR></TABLE>
Yes traction bars really do help, a lot. The full race and jimfab ones are great. I still have the old z10 bars, but I feel no need to upgrade, I have no wheel hop, now I just have wheel spin. One other thing you can do is install a urethane rear motor mount.
steve
Old May 9, 2005 | 09:04 PM
del_orson's Avatar
Default Re: how to get rid of wheel hop (salt)
i have upgraded motor mounts.
Old May 10, 2005 | 05:01 AM
EG6R's Avatar
I got rid of mine by stiffening up the rear suspension.
Old May 10, 2005 | 05:23 AM
DIFFUT'S INC.'s Avatar
Default Re: how to get rid of wheel hop (EG6R)
what tires u running ?
Old May 10, 2005 | 05:33 AM
Goinfasterthanu's Avatar
Got mine out by getting 5 way adjustable struts and putting them on 5...No more wheel hop..
Old May 10, 2005 | 05:43 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">I got rid of mine by stiffening up the rear suspension. </TD></TR></TABLE>
what did you do? bushings, springs, etc..?
Old May 10, 2005 | 06:46 AM
1750cc's Avatar
Default Re: how to get rid of wheel hop (smokey2.0)
- soften ur front tires
- soften ur front suspension
-stiffen ur rear suspension
-change tires to something soft if ure using low profile
Old May 10, 2005 | 08:16 AM
scoop's Avatar
traction bars
Old May 10, 2005 | 02:45 PM
smokey2.0's Avatar
Default Re: how to get rid of wheel hop (1600cc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1600cc &raquo;</TD></TR><TR><TD CLASS="quote">- soften ur front tires
- soften ur front suspension how soft? too broad of a statement
-stiffen ur rear suspension adding heavier weight rating springs, will help
i actually made my front suspension stiffer, and it still hopped but not as much as before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scoop &raquo;</TD></TR><TR><TD CLASS="quote">traction bars </TD></TR></TABLE>
running full race, and i still get wheel hop! i'll need some track time, to come to a solution for the wheel hop! is anyone using limiting straps? can you guys chime in! btw my comments are about, street tires BFG drag radials in particular!
Old May 10, 2005 | 04:57 PM
EG6R's Avatar
I put the front springs in the rear with loads of bumpstops and around 40 psi on the rear tires.
Old May 11, 2005 | 12:30 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">I put the front springs in the rear with loads of bumpstops and around 40 psi on the rear tires. </TD></TR></TABLE>
why not just get a set of 900+ lbs springs, and put them in the rear. i thought of doing the bummp stop thing, but i figured that having a damp adjustable shock with high LBS springs in the rear would work best!
Old May 11, 2005 | 02:29 AM
EG6R's Avatar
Of course it would! But $3 worth of bumpstops vs $1500 teins, well..
Old May 11, 2005 | 05:31 AM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6R &raquo;</TD></TR><TR><TD CLASS="quote">Of course it would! But $3 worth of bumpstops vs $1500 teins, well.. </TD></TR></TABLE>no way i would pay that much, just buy a set of rear skunk2 drag springs rated @ 900lbs they cost 100-130 for the rears only
Old May 16, 2005 | 05:35 PM
smokey2.0's Avatar
no one else has anything to say on this
SilverPanda
Suspension & Brakes
Sep 4, 2007 01:37 PM
CAVTECSol
Aug 6, 2006 08:27 PM
playboyace35
Feb 18, 2005 03:01 PM
elevatethis
Jun 2, 2003 09:22 AM
lsvtec94
Aug 25, 2002 07:04 PM
