d.On the drive home, I noticed my clock wasn't lighStrange Electrical problem
Old May 9, 2005 | 07:15 PM
Double_Dk's Avatar
Default Strange Electrical problem
Hey all.
Drove to work today, all was good. On the drive home, I noticed my clock wasn't lit up. Thought it got blown. Radio worked. Double checked the fuse, and all was good. Noticed that in addition to the clock, the turn signals, fuel meter, and heat meter do not work. But the 4 ways do.
The fuse was blown for the turn signals, replaced it, and it blew again .
Any ideas?
Modified by Double_Dk at 9:02 PM 5/10/2005
Old May 9, 2005 | 09:33 PM
ServiceAdvisor's Avatar
Replace the turn signal bulbs, replace the fuses, is your alternator over/under charging? Lights dim on revs or illuminate more? Check the fuse for instrument lights under the dash. - Darrell
Old May 10, 2005 | 01:27 PM
Double_Dk's Avatar
Light illuminate slightly on rev.
Lights under speedo work, and the speedo works. just not hte fuel or temp.
Clock is no dice, and the fuses keep popin
Old May 10, 2005 | 01:41 PM
Pull the plastics off and start tracing wires, check at 1 end with a multimeter and then check other. If theres' a large diff then you might have possibly found your problem. Sounds like a short draining the battery/charging system. - Darrell
Old May 10, 2005 | 05:03 PM
Double_Dk's Avatar
It's been doing the illumination thing for a while. Didn't bother me. But I don't get why my 4 ways work, my radio works, but the other stuff doesn't.
S33
Dec 27, 2014 10:22 AM
Heart4Tuners
Jul 24, 2011 11:33 AM
O16581724 5 2 5
Oct 6, 2005 10:03 PM
Double_Dk
May 15, 2005 04:39 PM
payneth
10
Apr 15, 2004 03:59 PM
