bogging down problems....
Old May 9, 2005 | 05:47 PM
civics8900's Avatar
Default bogging down problems....
yeah i just put a motor swap in my civic. b16, when im at a stop i let out the clutch and ease on the gas like normal when i have the clutch all the way out i still press the gas but it like slowly picks up speed, i think it is either im puttin out to much fuel or something. If anyone knows please help me out. im gettin a fuel pressure gauge in a couple of days so i will definently know how much fuel im puttin out. but if you know something let me know, i would really appricate it.
Thanks
Old May 9, 2005 | 06:38 PM
Hurricane's Avatar
Default Re: bogging down problems.... (civics8900)
Does it do the same thing cold as when its warmed up?
Old May 9, 2005 | 06:41 PM
n1mr0d's Avatar
I only ask because I have seen it done. Are the spark plug wires in the correct order? Are all the connections tight? Did you switch out the computer?
Old May 11, 2005 | 03:10 PM
civics8900's Avatar
Default Re: bogging down problems.... (n1mr0d)
well when it is cold and it is idling the rpms are high so its ok, but when it warms up alittle then thats when it starts. um it usually does it like 1-4000 rpms, i was thinkin it might be my fuel filter also. i dont know well if you think u might know what it is let me know, thanks
Ronnie
Old May 11, 2005 | 04:21 PM
SantaCruz92Si's Avatar
im having a problem with my d16z6, changed my fuel filter couple months ago with oem.... bump for the info!
Old May 12, 2005 | 04:26 AM
Hurricane's Avatar
Default Re: bogging down problems.... (SantaCruz92Si)
I am having the same problem with my D16Z6, gonna put a refurbed dizzy on it today and see if that is the problem.
Old May 12, 2005 | 12:10 PM
Default Re: bogging down problems.... (Hurricane)
changed mine, didnt help....
Old May 12, 2005 | 06:58 PM
civics8900's Avatar
its not the fuel filter, i dont know what it is. maybe my air control valve!
Old May 13, 2005 | 04:34 AM
Hurricane's Avatar
Replace your plugs, cap and rotor yet?
https://honda-tech.com/zerothread?id=1238078
CimorelliCRX
Apr 7, 2022 12:16 PM
5speedchick
Feb 21, 2012 05:43 AM
4tika4
29
Jan 26, 2010 02:06 PM
hatchish
May 2, 2005 10:31 AM
dizzyroc88
Mar 15, 2004 07:17 PM
