code 41 after intake install?
i got a code 41 (primary oxygen sensor heater) on my buddy's stock 95 civic ex. i tried to reset it several times, and its been like 4 months and the CEL stays on. do i just need to replace the o2 sensor? why would it just go bad at the same time as the intake install? and which sensor is it?.. i did a search but couldnt find out exactly what a primary oxygen sensor HEATER was.
it seems like just a coincidence. the primary o2 sensor heater just heats up the element so the ecu can run in closed loop mode sooner. to replace the heater you must replace the entire o2 sensor.
hmm thats wierd. it seems like everytime i work/get work done on my car, something else breaks at the same time...
anyways thanks alot for your help.
924drb20
Dec 14, 2010 10:36 AM
JibOnALib
Aug 25, 2005 08:54 PM
Viorent Grip! EG
May 2, 2004 06:29 AM
