k20 swap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gass04ex »</TD></TR><TR><TD CLASS="quote">i got this guys.
» Search Results
Your search for k20 swap returned 12 results</TD></TR></TABLE>
i got better
» Search Results
Your search for k20 swap returned 137 results.
u forgot to hit achived
» Search Results
i got better
» Search Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cfk182 »</TD></TR><TR><TD CLASS="quote">thanx alot of the info now that i kno its a little to pricey what do u htink would be the best swap for say 5000 for me ek?</TD></TR></TABLE>
depends.
do you want to go turbo or all motor?
depends.
Great question; I don't think that's ever been asked. You keep coming up with really interesting questions.
The hardest part of this swap is the wire harness and getting past the immobilizer (if the stock ECU is used).
Uhhhhhh one that runs? You need to do some research before you ask anymore questions. Think about these while you do it:
-Do you wanna spend all $5000 on just a engine?
-Do you wanna go all motor or turbo?
-Do you know how to do a swap yourself?
-Do you know how to fix something if it breaks?
-Can you afford to keep a built engine running?
i recomend not going k series at all. im not nockin on your taste but if you plan on really goin somewhere with this engine then you might need to know they have really weak rods and my friend Dean has had to k series motors and both of them lost compression. so to tell you the truth i would def. go b series
Would it be possible to use up all $5k on your stock engine? For that much you could make that thing fly
Okay so I don't really know anything, but just offering another idea!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5gSiB20 »</TD></TR><TR><TD CLASS="quote">i recomend not going k series at all. im not nockin on your taste but if you plan on really goin somewhere with this engine then you might need to know they have really weak rods and my friend Dean has had to k series motors and both of them lost compression. so to tell you the truth i would def. go b series </TD></TR></TABLE>
Wow, and you think there is an endless supply of b series engines? He can always rebuild the k20 if anything goes wrong with it internally. With how many people are shooting rods or completely destroying their b series engines, they will be obsolite LONG before the k series have even begun to scratch the surface of a dominating hybrid swap.
u can get K20a2 swaps for alot less than 4500. And u can make everything for the swap fairly easy (i bought mounts), u dont need the fuel system from a rsx?...just get a golden eagle fuel rail and aeromotive regualtor and -6 lines to connect them and its done. U can go the swap installed into a eg for less than 4g no problem
I believe you need all the tranny from RSX, so basically you will be driving with 6 speed transmission from RSX. Also, I believe K20 is a bit heavier than B series engines, therefore, you need to find a way to reduce some weights while swapping.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoon-EK9 »</TD></TR><TR><TD CLASS="quote"> Also, I believe K20 is a bit heavier than B series engines, therefore, you need to find a way to reduce some weights while swapping.</TD></TR></TABLE>
No, they are lighter. And you can use any of the k series trannies. But the Type S 6 speed is the best.
