New and need advice!
Hello. I have an 89 Honda Civic hatch, and i have the need for speed
. I've seen some pretty nasty civics out there and i was just wondering what i should do first with my "somewhat stock" DX engine (atleast i think its a DX). If someone knows where i can get a turbo for my hatch and or can give me advice on where to start i would appreciate it. Here are some pictures... BTW bro-in-law made that wicked intake :-o
Well i just baught this brand new engine ...well kinda new... 1500 miles on it... and the tranny (5 speed). Also what turbo do i get? And what all do i need to buy? The more horsepower the better!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">multi point fuel injection conversion, along with an si ecu and tranny aught to be a good start. Or you can throw a zc in there.</TD></TR></TABLE>
Any ideas where i can find all of thee above?
http://www.4gcivic.net for guides on doing the ZC or the mpfi swap. Well, to do the ZC swap you have to do the mpfi. And if you want to do any turbo you have to do the mpfi....
So I would start with the mpfi :-)
Thnx...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">which motor did you buy?</TD></TR></TABLE>
Thats another thing. I have no clue :-\. This friend of mines friend (who sold me the engine) told me it was a b15, but apparently B15's dont exsist, so i was told. Also what i was told was this motor was imported from Japan, from a stock hatch, and is supposed to be a very good engine. He also put a little work in it himself supposedly added bigger pistons.
The type of motor it is, is a mystery really. :-(
Thnx for that link btw^^^
Modified by HondaMan32004 at 5:26 PM 5/9/2005
http://www.homemadeturbo.com for all your turbo needs
and a MPFI conversion is a must! MPFI just do a search make sure to click the archive button for the older stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaMan32004 »</TD></TR><TR><TD CLASS="quote">Thnx...
Modified by HondaMan32004 at 5:22 PM 5/9/2005</TD></TR></TABLE>
so this motor isn't the one currently in your car? from what you said, it sounds like it's the JDM d15b (sohc vtec) motor. if the motor you're talking about is the one in the pictures, then you've got a regular DX motor (1.5L non-VTEC DPFI).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">then you've got a regular DX motor (1.5L non-VTEC DPFI)</TD></TR></TABLE>
Thats probably what it is ^^^ Although i was told its not stock.
_________________________________
Which one of these would be ok?
http://cgi.ebay.com/ebaymotors...=WDVW
Let me know which you all would recommend. Thnx.
Modified by HondaMan32004 at 5:52 PM 5/9/2005
Modified by HondaMan32004 at 5:54 PM 5/9/2005
the d15 is as stock as it gets. Down to the dual point carb. fuel injection. Even as a stock motor its still got some peep to it. I wouldn't look into turboing that motor, or you will be searching for a new one soon after. I would suggest a zc swap. I have done a couple and they are easy. Hardest part is the wiring but that takes no time. Everything is bolt up. Even the DOHC zc drops in and gives a nice bet of power and aggressive look. And ZC engines are good for boosting with their low Compression. Right now running two civics, one with a DOHC ZC turboed running 7-8 psi and one running a SOHC zc non-turboed. Both motors run great and are great upgrades from the stock motor. Good luck with your honda, and post when you make up your mind
what can i do with this engine to add more HP if it is what you say it is? ECU?
And what do you think about this?
Modified by HondaMan32004 at 6:38 PM 5/9/2005
i wanted to buy one of them, and i would have if i didnt have the one i got now usdm d16. anyways that thing will pull hard with 140 torque, just throw on some bolt ons and like it says youl hang with the dohc vtecs. i dont know much about guit-guit the guy who sells it, but he does sell a lot of stuff
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explictness »</TD></TR><TR><TD CLASS="quote">CRX DX's have 113 torque? i never knew that. Cool i just learn something.
that's alot of torque in your foot use it wisely
</TD></TR></TABLE>that's alot of torque in your foot use it wisely
lol.
i know this seems to be jokes, but crx dx's have like no torque, less than 100.
and, by looking at the exhaust manifold, that car appears to be an std. the only differences between the dx and std engine are the computer, camshaft, some pieces in the intake, and the exhaust.
however, the std has tiny axles, tiny front brakes, and a 4 speed tranny.
I would get a bigger engine, and do a mpfi swap. The wiring is easy with a rywire.com harness, and the how to can be found at my site http://www.droppedcrxsi.com
Ryan
Ryan
madbass1
Aug 31, 2004 11:06 AM
the DR.
Jan 18, 2002 07:09 PM
