stripped?
i went to go change my oil today, and niether the 14mm or 15mm fit!? my so my question is if i do manage to take it out somehow are the threads that it screws into my oil pan gunna be fucked?
i have an aftermarket magnetic one
so would the threads inside the oil pan be stripped? or would a new one just screw right in?
worst case senerio, is the inside is stripped to, i heard they sell half sizes and stuff right, so u can make new threads or something?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx »</TD></TR><TR><TD CLASS="quote">no stripped, just that bolt is really hard to get off. I know i had to put the wrench on mine and give it a swift kick, and it is not threaded.</TD></TR></TABLE>
the head of the bolt is stripped tho, im just wondering if the threads inside my oil pan are stripped
is there anyway to tell if the threads are stripped? i dont wanna take it off and then not be able to drive anywhere cuz i cant hold the oil in (if the threads inside the oil pan are stripped)
will will jb weld will hold it? so if the threads are stripped, put the bolt in there and put jb weld all around it the sides of the bolt? sry for keep asking, thanks for everyones help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ratboy »</TD></TR><TR><TD CLASS="quote">is there anyway to tell if the threads are stripped? i dont wanna take it off and then not be able to drive anywhere cuz i cant hold the oil in (if the threads inside the oil pan are stripped)
will will jb weld will hold it? so if the threads are stripped, put the bolt in there and put jb weld all around it the sides of the bolt? sry for keep asking, thanks for everyones help</TD></TR></TABLE>
You will know if the threads are stripped IE they wont be there or will be squished down. I think your worrying too much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sadangryboi »</TD></TR><TR><TD CLASS="quote">take it out, drain it, re-tap dye if neseasary</TD></TR></TABLE>
Heres a towel. I just spooged on your avatar.
SpeedMonkeyRacing
Aug 7, 2003 07:07 AM
