AEM Fuel Rail Leaking ???
Old May 9, 2005 | 12:20 PM
InTeGrA GsR 321's Avatar
Default AEM Fuel Rail Leaking ???
I can't get this leak to stop....It's not leaking out of my injectors, it's out of the secondary 1/8 fitting for my fuel gauge...It leaks with the gauge in there and the the plug in there...I was told to use Teflon Tape, but the AEM direction says not to and B&M fuel gauge say to... ???..... YES OR NO ??? And will that make it stop leaking ???
Old May 9, 2005 | 01:20 PM
turbo_b16_ex's Avatar
well if it leaks i would use teflon. not sure if gasoline would deteriorate it but see if thatll fix problem
Old May 9, 2005 | 03:41 PM
eMpAtHy's Avatar
Default Re: (turbo_b16_ex)
if its installed correctly, it shouldnt leak. is it near the banjo bolt? if it is, did u put the correct amount of washers? i put an extra one and i had a bad leak. is everything tight? are all the o rings there?
Old May 10, 2005 | 11:52 AM
Default Re: (eMpAtHy)
It's not on the fuel filter, so the leak has nothing to do with the banjo bolt...AEM rails have a 1/8 fiting for a fuel gauge on the fuel rail next to the FPR...It's leaking out of there, even with the plug bolt that comes with the AEM rail...Rail directions say not to use teflon tape, but fuel gauge says to use it...Will it do an harm and will it work ???
Old May 19, 2005 | 11:20 AM
HondaNerd's Avatar
Default Re: AEM Fuel Rail Leaking ??? (InTeGrA GsR 321)
First improper installation
Might wanna try the D1 fuel RAIL...
http://www.datum1.com
Their fuel rail had complaint but it turns out that -- peepz was installing it incorrectly.--
change injectors O-rings.. check clearance-- recommended use is 94+ Acura integra --o-rings. teflon the end and--- you got yourself a non -leaking set-up..
Old May 19, 2005 | 09:07 PM
Garcia-Racing's Avatar
Use some teflon paste on the threads of the guage.
WH0R3nEF9
Apr 1, 2005 09:52 AM
alpha
Jun 14, 2003 07:19 PM
greddyturboGSR
Mar 10, 2003 05:48 PM
