Honda S2000 Honda S2000
S2000 CLUTCH JOB....WHATS INVOLVED????
Old May 9, 2005 | 12:20 PM
99lspwr's Avatar
Default S2000 CLUTCH JOB....WHATS INVOLVED????
Hey phellas, I might be doing a side job for someone who needs a clutch installed in a s2k....Is there anything goofy to look out for???He called the honda dealer and they told him 925 for just labor alone!!! I thoght that was kind of high!!! Any suggestions would be helpful....Oh, yeah this will be done at home not on a lift...thanks
Old May 9, 2005 | 12:43 PM
Mr. Bagel's Avatar
Default Re: S2000 CLUTCH JOB....WHATS INVOLVED???? (99lspwr)
if this is a side job and you haven't done it before, don't. this is the ONE thing that I paid someone else to do - a very reputable shop. it ran just under 500 for the install + rear main seal while he was in there. dealer wanted 685. I supplied the parts.
basically, you'll want a lift, and you'll also want air tools. you'll need to drop the front cross member, along with the engine, down about four inches. if you don't have a lift nor air tools, it isn't worth it IMO.
Old May 9, 2005 | 02:05 PM
Shift@9k's Avatar
Default Re: S2000 CLUTCH JOB....WHATS INVOLVED???? (Mr. Bagel)
i wouldnt try it man it will be a B*tch w/o a lift! i did my freinds clutch on his FD rx7 w/o a lift it sucked to say the least. Good luck tho!
Old May 9, 2005 | 02:28 PM
Francesco's Avatar
Default Re: S2000 CLUTCH JOB....WHATS INVOLVED???? (Shift@9k)
from what i hear you have to tilt the motor...
Old May 9, 2005 | 04:06 PM
Kenso's Avatar
HT White Ops
Default Re: S2000 CLUTCH JOB....WHATS INVOLVED???? (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">from what i hear you have to tilt the motor...</TD></TR></TABLE>
I don't think you're gonna want to do this one on the ground.
Old May 9, 2005 | 04:10 PM
Nishant's Avatar
Default Re: S2000 CLUTCH JOB....WHATS INVOLVED???? (Kenso)
i do not suggest you doing this as a side job. at a minimum have a helms for the S. i'd ask some shops who have done work on a S before and see what they charge.
Old May 9, 2005 | 07:17 PM
rickbailey's Avatar
what if u jack the car up buy a tranny jack i think it wouldnt be so hard.
Old May 9, 2005 | 07:28 PM
fknfast's Avatar
Default Re: (rickbailey)
May GOD & and a lift be with you!
Old May 9, 2005 | 08:17 PM
tilt's Avatar
I've helped replace one. As long as you have the car up pretty high on stands and have a helper(s), though more involved, it isn't that much worse in difficulty than a fwd honda clutch job. Just be prepared for awkward bolts to get to. I'd set aside a full weekend if it's your first time.
Info that I used:
http://forums.s2ki.com/forums/...83548
reverendsgarage.net (seems to be down)
helms
Old May 10, 2005 | 04:39 AM
Francesco's Avatar
Default Re: S2000 CLUTCH JOB....WHATS INVOLVED???? (tilt)
i think it just comes to the fact that you get a recipt from letting a shop do it vs. doing it yourself...if something happens they will fix it cause you paid for it...no one want's cluctch rattle or any order side effect from not having it installed right...
im not knocking your mechanical skills, because i would like to learn how do this, but for now i have to pay people and watch...
Old May 10, 2005 | 05:59 AM
99lspwr's Avatar
Thanks for all the help, I have no doubt that I can do it, just the question is if it really is worth it when it comes down to it...I still cant believe the dealer told him 900+ parts!!!
Old May 10, 2005 | 06:39 AM
Mr. Bagel's Avatar
call around to a few independents to see what they would charge.
Old May 10, 2005 | 07:25 AM
fknfast's Avatar
i wouldnt do it cheaper than $600..
6Speed Kansas
Honda S2000
Aug 15, 2017 01:36 PM
redLUDEs2k1
Honda S2000
Aug 29, 2008 12:11 PM
qwikkid87
Honda S2000
32
Jan 15, 2006 09:19 AM
whitericelova
Honda S2000
Nov 14, 2004 01:14 PM
FK00GSR
Nov 30, 2002 02:41 PM
