Dirty clutch disc... what to clean with ? searched.
Old May 9, 2005 | 10:37 AM
lojackgsr's Avatar
Default Dirty clutch disc... what to clean with ? searched.
I have tried to search, but I want to know what is safe to clean the whole clutch disc and pressure plate surface with, I was thinking brake cleaner? let me know guys thanks!!
Old May 9, 2005 | 11:01 AM
tgreaves's Avatar
Default Re: Dirty clutch disc... what to clean with ? searched. (btownSI)
Brakeen!!!
Old May 9, 2005 | 11:04 AM
lojackgsr's Avatar
Whatttt?!
Old May 9, 2005 | 11:24 AM
DOHCsideracing's Avatar
Default Re: (btownSI)
Brakleen, is a particular brand of brake cleaner... Available at most auto parts stores.
I think most any brand will work (???)
I always just use strong solvents, (MEK, lacquer thinner, etc.) but brake cleaner would work fine, too (IMO).
If the disc is soaked in oil/grease/whatever, it might make more sense to get a new one, because the oils will leach out forever, and form slippery carbon deposits if you don't get them out. The PP and flywheel are easy to clean so they aren't a problem, but the disc being porous, sucks up a lot more of that stuff, and embeds in it the lining.
Good luck.
A
Old May 9, 2005 | 12:13 PM
citrus3000psi's Avatar
Default Re: (DOHCsideracing)
Excellent Info
Old May 9, 2005 | 01:45 PM
lojackgsr's Avatar
Thank you for this information. The disc is actually not soaked or very very dirty at all, it just has some noticable things i'd like to clean off of it before I install it, well I guess now it's just time to work, thanks guys.
thedudefromjerz
Jan 15, 2010 04:46 PM
thebleek
Transmission & Drivetrain
Nov 20, 2008 07:02 PM
acurar0ss
Dec 16, 2004 04:39 AM
Convoy
May 20, 2004 10:41 AM
VTgringo
Aug 9, 2003 04:06 PM
