why does the 117hp HX engine get better mileage then the 115hp VP engine?
Old May 9, 2005 | 10:27 AM
rody084's Avatar
Default why does the 117hp HX engine get better mileage then the 115hp VP engine?
Hi,
I am looking to buy a 2005 civic and I see that the Hx gets the best gas mileage. I am wondering why it gets substantially better mileage than the VP which has 2hp less horsepower
thank you!
Old May 9, 2005 | 10:29 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: why does the 117hp HX engine get better mileage then the 115hp VP engine? (rody084)
Maybe the VP is heavier
Old May 9, 2005 | 10:36 AM
Luserkid's Avatar
Default Re: why does the 117hp HX engine get better mileage then the 115hp VP engine? (SkoundrelUSA)
whats the VP?
Old May 9, 2005 | 10:38 AM
92rps13's Avatar
Default Re: why does the 117hp HX engine get better mileage then the 115hp VP engine? (Luserkid)
i wouldnt buy a new civic unless its lx or ex because they are vtec, but it depends on what you want. i have an 04 ex and i get 38 mpg in it. in the city.
Old May 9, 2005 | 10:39 AM
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">whats the VP? </TD></TR></TABLE>
It's like a newer model CX but a coupe (i think) sort of. ITs weird.
http://auto.consumerguide.com/...owall/
Old May 9, 2005 | 10:47 AM
AutoXer's Avatar
Default Re: why does the 117hp HX engine get better mileage then the 115hp VP engine? (gass04ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gass04ex &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt buy a new civic unless its lx or ex because they are vtec, but it depends on what you want. i have an 04 ex and i get 38 mpg in it. in the city.</TD></TR></TABLE>
LX doesn't have VTEC, only the EX.
Old May 9, 2005 | 10:53 AM
jolt-tsp's Avatar
Default Re: why does the 117hp HX engine get better mileage then the 115hp VP engine? (AutoXer)
VP is just the value package LX I beleive. The reason the HX gets better milage is because it's a more efficient engine in a lighter car. More HP != less milage. The HX has a lean burn system that only opens one intake valve and barely opens the other before vtec kicks in. VTEC kicks in early though, at 3k rpm, so that you don't hang in the no power range very long. Basically at cruising speed in a HX you get great milage, but when you open it up, it jumps to vtec quick to give you the power you need. Also the HX has little things like roller rocker arms on the valve train and lighter wheels to help increase milage.
Old May 9, 2005 | 10:58 AM
TallAssFilipino's Avatar
I know this is off-thread, but have you guys seen the new Lexus Hybrids? Their system is pretty sweet.
Old May 9, 2005 | 12:06 PM
.Beaver's Avatar
Bloody Beaver
Default Re: why does the 117hp HX engine get better mileage then the 115hp VP engine? (MDJ IKNJ)
the HX motor is engineered to be high mpg...
Old May 9, 2005 | 12:38 PM
logikalfury's Avatar
i just copied the following from that site that SkoundrelUSA posted:
All Civics come with manual transmission, and all but DX and Si offer automatic.
haha the dx only comes in manual??????? too funny
as to answer the question, does the civic hx still have the vtec-e opposed to the vp not having it?
Old May 9, 2005 | 03:26 PM
rody084's Avatar
Default Re: why does the 117hp HX engine get better mileage then the 115hp VP engine? (jolt-tsp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolt-tsp &raquo;</TD></TR><TR><TD CLASS="quote">VP is just the value package LX I beleive. The reason the HX gets better milage is because it's a more efficient engine in a lighter car. More HP != less milage. The HX has a lean burn system that only opens one intake valve and barely opens the other before vtec kicks in. VTEC kicks in early though, at 3k rpm, so that you don't hang in the no power range very long. Basically at cruising speed in a HX you get great milage, but when you open it up, it jumps to vtec quick to give you the power you need. Also the HX has little things like roller rocker arms on the valve train and lighter wheels to help increase milage.
sweeeeet! sounds perfect for what I want!
Anyone know if this car is more expensive to repair?
Old May 9, 2005 | 05:00 PM
jolt-tsp's Avatar
One thing is the later model 2001-2005 doesn't come with ait conditioning stock.
Really, I'd take a used one anyway (96-00), you'll find aftermarket parts easier to come by. Things are upgradable with Civic EX/Si/Integra parts (you'll probably want to change the transmission and brakes over to EX ones eventually), so you can upgrade for CHEAP. The wheels are light, and can fit 195 azenis on them so no need to replace them. It's so light that a suspension upgrade really makes it go. There's just a ton of good things about it and nothing bad really.
I'm running a 97 HX as a track only car now. It's stripped. I replaced the power steering with the DX manual rack. I'm using CRX Si seat bottoms (helps hold in much better than the stock seats). Running the stock wheels with 195 Azenis on them. GSR swaybar with Si endlinks in the rear. DSM T25 turbo off a CRX Hf manifold. Integra rear disc brakes (don't have the fronts just yet, and they're really the more important ones :-\ ), Civic EX transmission. All those parts are off other cars so they came in really cheap. And the entire time you're modding the car you're getting 40+ mpg, without foregoing the power windows and locks :-p
And oh ya, it has VTEC-E too.
Anyway, I tend to go on about the HX, but mine has gone from my daily driver to my audio car to my stolen car ( ) to my track car, and has excelled in every area.
dfdsasdf114
14
Jun 26, 2007 08:36 AM
chingob
Honda Civic (2001 - 2005)
Feb 22, 2007 02:20 PM
mushu315
14
Mar 30, 2005 10:16 PM
TypeR[S]
18
Feb 22, 2005 05:02 PM
skrewdriver88
May 10, 2004 10:44 AM
