gauge fuel needle
Old May 9, 2005 | 08:01 AM
pleekh73's Avatar
Default gauge fuel needle
i have a civic 98 EK with a fuel/temp gauge. I want to slide in the new white face over the black face. I know i can move the temp. needle around so that i can fit the new face as the temp. needle will return back to the bottom, what about the fuel needle? I tried moving it slidely and it didn't go back to the original position!! Will i screw up the fuel reading???
Old May 9, 2005 | 08:36 AM
AutoXer's Avatar
Default Re: gauge fuel needle (pleekh73)
You may have broken it. They're very sensitive. If you go to http://www.slhondaparts.com you can get a replacement for it for around $20.
Old May 9, 2005 | 09:46 AM
JDM-EJ1's Avatar
Default Re: gauge fuel needle (AutoXer)
It should slowly fall back down. You can always put the guages on and then see if it works.
Old May 9, 2005 | 09:47 AM
pleekh73's Avatar
i don't think i have broken it. I think you have misunderstood my question. Can i move the fuel needle to fit a new gauge face??
thanks.
Old May 9, 2005 | 09:50 AM
pleekh73's Avatar
Default Re: gauge fuel needle (JDM-EJ1)
if i have half tank of fuel, and i move my fuel needle to full and plug the gauge cluster back, the fuel needle will go back to the actual reading of half tank?? please confirm?
Old Jul 2, 2005 | 11:48 PM
wwang924's Avatar
I heard that ppl mark it, So if you move it you have to put it back into the original position. For me, I have a different problem, my friend was trying to be mr. technician and broke my fuel needle. Any how-to's on replacing or repairing? for now i tried glueing it, not looking too good.
Old Jul 3, 2005 | 12:08 AM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pleekh73 &raquo;</TD></TR><TR><TD CLASS="quote">if i have half tank of fuel, and i move my fuel needle to full and plug the gauge cluster back, the fuel needle will go back to the actual reading of half tank?? please confirm?</TD></TR></TABLE>
once u turn on the car the needle will auto readjust to the ammont of gas in your tank
Old Jul 3, 2005 | 05:41 AM
SlowHX's Avatar
I've also broken off my fuel needle and temp needle . i visited http://www.slhondaparts.com/ like suggested, but I'm lost where to find the parts needed to repair the needles. Any suggestions?
Old Jul 3, 2005 | 08:14 AM
JDM-EJ1's Avatar
Default Re: gauge fuel needle (SlowHX)
I broke off my fuel needle when I installed my guages, my needle broke off. I was always under the impression that once a needle has been broken off it CANNOT be replaced, the whole guage itself would have to be replaced.
Old Jul 3, 2005 | 09:37 AM
wwang924's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowHX &raquo;</TD></TR><TR><TD CLASS="quote">I've also broken off my fuel needle and temp needle . i visited http://www.slhondaparts.com/ like suggested, but I'm lost where to find the parts needed to repair the needles. Any suggestions?</TD></TR></TABLE>
yesssss score! hahah i found it. I was looking for it tooo. You cant replace the needle, but you dont have to replace the whole cluster, just that section.
http://www.slhondaparts.com/br...NENTS
Modified by wwang924 at 1:39 PM 7/3/2005
Brosseau
Honda CR-V & Element
Jul 26, 2018 03:15 PM
Roryz
May 14, 2014 05:14 AM
radarhater
Honda Motorcycles
Jun 2, 2007 08:33 PM
Driven
Jun 28, 2006 06:14 AM
