H22 or H22 type-s
Old May 9, 2005 | 07:24 AM
Hatchorama's Avatar
Default H22 or H22 type-s
I'm saving up to an H22 or H22 type-s for my hatchback si. and it will be turbo'd. Can someone tell me the ups and downs of both motors if I were to go turbo and what you think I should do?
Old May 9, 2005 | 07:43 AM
IHateJDM's Avatar
Default Re: H22 or H22 type-s (Hatchorama)
type s is a waste of money if you want to go turbo. with fi, you want lower compression, not higher (usdm h22 = 10:1, jdm h22=10.6:1, type s=11:1).
Old May 9, 2005 | 08:51 AM
JDM H23A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchorama &raquo;</TD></TR><TR><TD CLASS="quote">and it will be turbo'd. if I were to go turbo</TD></TR></TABLE>
So which is it?
Old May 9, 2005 | 09:03 AM
canis's Avatar
if you did run just NA, the higher comp. but since you are going to turbo that **** you wanto lower the comp some but not to much like down to 10:1 witch would be fine then run about ~8+ lbs and it would be nice....
Old May 9, 2005 | 01:12 PM
Hatchorama's Avatar
couldn't I go with the type-s and just use a thicker head gasket?
Old May 9, 2005 | 01:14 PM
BlueIntegraBoy's Avatar
Default Re: (Hatchorama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatchorama &raquo;</TD></TR><TR><TD CLASS="quote">couldn't I go with the type-s and just use a thicker head gasket?</TD></TR></TABLE>
Of course, you are spending more money on something you don't need. You don't need the higher compression pistons or the better cams. Save your money, get a USDM H22 and spend it towards your turbo parts.
Old May 9, 2005 | 01:19 PM
.BigSexy's Avatar
most hood white kid
a turbocharged h22 in an eg is more trouble than I would go through. but if u are gonna boost, go with lower compression like everyone else said
Old May 9, 2005 | 01:46 PM
The Droogan Leader's Avatar
Now with ultra-violence!
I'm with everyone else, an H22 isn't usually the first choice if your going to boost. Personally, if it were me, I'd pick up a newer, clean, B18B. I'd then build-up the internals for boost.
Your choice though...
Old May 9, 2005 | 01:56 PM
.BigSexy's Avatar
most hood white kid
Default Re: (Shin-tegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shin-tegra &raquo;</TD></TR><TR><TD CLASS="quote">I'm with everyone else, an H22 isn't usually the first choice if your going to boost. Personally, if it were me, I'd pick up a newer, clean, B18B. I'd then build-up the internals for boost.
Your choice though...</TD></TR></TABLE>
eveyone does this....build the single slam and then boost!
Old May 9, 2005 | 08:18 PM
5gSiB20's Avatar
Default Re: (egcoupe94)
have fun wiring that bitch up and spendin money sleevin that ho b4 boostin it.(shitty cylinder walls)(well atleast all my friends had shitty cylinder walls)
Old May 10, 2005 | 06:52 AM
hseriescivic's Avatar
Personally i would go with the h22 because of the lower compression than the type s motor. The cylinder walls are really not the problem if you want to run around 5-7 psi. The ringlands ussually go bad on the h series motors. My friends has been running his h22 and 8 psi for 7months now and has had no problems. But then again it was very well tuned. If I were to boost any more than that on my motor i would go all out on the motor first. I would have the block blueprinted and sleeved go forged pistons and rods and all new valve train. But thats just me i like to know my setup is going to be reliable1
Old May 12, 2005 | 06:58 AM
Hatchorama's Avatar
Yeah, I think I will just get a USDM H22 unless I find a JDM H22 for a good price, I found all the info I need, type-s's are good for all motor but I'm not interested in doing something like that, thanks for the help though.
theSQad
May 25, 2007 07:39 AM
vietkidracing
Jun 13, 2006 01:37 AM
huge230
Dec 6, 2005 03:46 PM
D1andOnly
Dec 2, 2005 03:42 AM
tunedbylorange.com
13
Jul 8, 2003 09:41 PM
