master cylinder options for EFs
what choices do I have for upgrading my MC? 15/16, 1" ???? Is it a bolt on affair or will it require rebending or flareing of the stock lines? plan on going for SIR knuckles and brakes, then eventually converting to prelude 11" rotors and calipers. anyone done this on their 4g?
i got one from 89 integ. i had to slighty bend one of the brake lines to fit. other than that, its perfect. the ef mc was $95 while the integ was $45..go figure
Panny, what up!
what year prelude did you use?
I'm gettin the brakes off a 2000 lude.
do you have pice of the setup?
what it a bitch to get to fit?(the lines)
all bolts up huh?
all bolts up huh?
I tried the 90-91 teg master cylinder ,it didn't bolt on. The flange is angled the opposite way when compared with the ef master.If you use the 90 teg booster as well I guess that would work. The 89 prelude one is the correct master to use as it will bolt onto the ef booster and is 15/16.
Actually, I was looking at prices, and a tilton MC is less than 100 bucks... Now getting the right one and fitting it properly, that's the challenge
Dan
Dan
Panny, what up!
all bolts up huh?
all bolts up huh?
P
#Leo#
Suspension & Brakes
Aug 3, 2013 06:38 AM
jiggatone
Suspension & Brakes
Apr 4, 2013 08:44 PM
#Leo#
Mar 15, 2009 07:57 AM
