How to paint a valve cover??
Old Feb 3, 2002 | 09:13 PM
vtec-outlaw's Avatar
Default How to paint a valve cover??
Anyone ever done this if so what is the best paint to do it with. I wanted to go withred like the type r valve cover but I dont want to pay $200. Flat red or gloss red. Spray or brush????? HELP
Old Feb 3, 2002 | 09:53 PM
KLN's Avatar
KLN
Default Re: How to paint a valve cover?? (vtec-outlaw)
go to your local auto store and find some paint that withstands atleast 500 degrees... theres also paint that can withstand 1200 degrees but you don't need that much...i don't know the name of the paint, but it is a in a spray paint can and has somethin' that saypoo pooemp" paint...also get this product called " graffiti remover"...its works wonders on takin' off the old paint from the valve cover
before:
after:
Old Feb 3, 2002 | 10:29 PM
FitCRX's Avatar
Default Re: How to paint a valve cover?? (KLN)
I wouldn't paint it...I'd pay....sorry dude but that paint looks like poo poo...but its all good
Old Feb 3, 2002 | 10:45 PM
o_Rage_o's Avatar
Default Re: How to paint a valve cover?? (FitCRX)
Rather than paint, you guys want Powdercoat, it makes it look original instead of shiny.
And if you choose to paint, the paint is called High Heat Manifold Paint, and is available in Matte and gloss...the picture above looks gloss.
Old Feb 3, 2002 | 11:04 PM
.nate's Avatar
Default Re: How to paint a valve cover?? (o_Rage_o)
Powdercoat
Old Feb 3, 2002 | 11:40 PM
threatcon13's Avatar
New User
Default Re: How to paint a valve cover?? (TheFLY)
aircraft paint remover? and high temp paint...sand it down after you strip it w/ a dremel.
Old Feb 4, 2002 | 08:33 AM
HaUTSaauce's Avatar
New User
Default Re: How to paint a valve cover?? (turbo01gsr)
wont need to sand it down if u use aircraft cleaner takes the paint right off
Old Feb 4, 2002 | 09:41 AM
Matt B's Avatar
Default Re: How to paint a valve cover?? (HaUTSaauce)
BBQ paint works good
Old Feb 4, 2002 | 03:11 PM
pub's Avatar
pub
Default Re: How to paint a valve cover?? (Lil Cs Zc)
You guys take off the valve cover when painting or do you just tape off and use newspaper? Im thinking about spraying on another layer of flat black.
Old Feb 4, 2002 | 03:36 PM
ken's Avatar
ken
Default Re: How to paint a valve cover?? (pub)
Yeah, take the valve cover off and cover anything you don't want painted (like spark plug holes, working, etc).
For, I just used flat blue caliper paint. I have people come up to me all the time while at the track asking if it was original.
Picture of it (big)
[Modified by ken, 4:37 PM 2/4/2002]
Old Feb 4, 2002 | 04:26 PM
pub's Avatar
pub
Default Re: How to paint a valve cover?? (ken)
looks great. (missin a screw though)
Old Feb 4, 2002 | 04:53 PM
KLN's Avatar
KLN
thanx...yeah, be careful when you put on the screws to not torque them to tight or they will break off
my valve cover is not glossy...it looks that way becuse the flash from the camera reflected off it makin' it look shiney...but in real life it looks a lot better cause i made the resolution of the picture low so it wouldn't take long to load which made the paint look uneven and blurry...
lilboxx
36
Apr 14, 2012 09:45 PM
-=ZAK=-
Jan 15, 2009 07:42 PM
ge_itr
Mar 27, 2007 01:49 AM
uses0ap
Mar 15, 2006 07:37 PM
