HELP!!whats going on??code 20
Old Feb 3, 2002 | 09:11 PM
vsual's Avatar
Default HELP!!whats going on??code 20
i'm getting a code 20 (electronic load detector) on my 91 si ecu. i dont know what happen. i've pulled the hazard fuse to reset the ecu a few times but it doesnt help. i've done a few searches about code 20 but cant seem to find the answer on this. any idea why or how i got that code20. what should i be looking for when troubleshooting on this?? all help is really appreciated. thanks in advance.
Old Feb 3, 2002 | 09:17 PM
Aphrodavid's Avatar
Default Re: HELP!!whats going on??code 20 (vsual)
ELD=electric load detector.
dont worry about it. i get it every so often. just pull the fuse for the ecu AND the one marked "hazard" and leave them off for about a minute, plug back in and the code should be gone.
Old Feb 3, 2002 | 09:27 PM
vsual's Avatar
Default Re: HELP!!whats going on??code 20 (DX-R)
thanks DX-R. i'll try that tomorrow. i'm tired from figuring out that problem the whole day. from 11am-9pm. i've checked all my wires if it was cut or touching something. thanks again.
Old Feb 3, 2002 | 10:35 PM
ImportHatch's Avatar
I got a code 20 too....
Yager-
Old Feb 4, 2002 | 09:17 AM
88_SC_CRX_Si's Avatar
New User
Default Re: HELP!!whats going on??code 20 (ImportHatch)
In most cases you end having to replace the main fuse box. The ELD is built into it, soooo you can't just replace it...
Old Feb 4, 2002 | 09:52 AM
red civic standard's Avatar
Default Re: HELP!!whats going on??code 20 (88_SC_CRX_Si)
I got a code 20 on my 89 crx dx. It turns out that one of my grounds was bad. I tightened up the ground and the code was gone.
Old Feb 4, 2002 | 01:40 PM
Aphrodavid's Avatar
ive NEVER seen an ELD sensor go bad. now thats not to say it doesnt happen. but in my experience, when you get error code 20, ususally you had a surge in the electrical system followed by the opposite. resetting the ecu and hazard will clear the code. now if you immediately get error code 20 again, then you may be looking at a bad ELD sensor, or like someone else said, a bad connection somewhere.
Old Feb 4, 2002 | 06:53 PM
vsual's Avatar
when you get error code 20, ususally you had a surge in the electrical system followed by the opposite.resetting the ecu and hazard will clear the code.
i've pulled the ecu fuse and the hazard fuse for 1-3 mins off then putting it back in. i'm still getting the code20. is the ELD sensor part of the main fuse box??what part of the main fuse box located at?? regarding about grounding or bad connections i've checked it the whole day yesterday. the grounding for the thermostat housing..the grounding on the cable tranny bracket and another grounding at the front of the car that connects to my valve cover....i've sand it down cleaned it and tighten the bolts down and still no luck. how do i check/find out if my ELD sensor is actually bad aside from the error code20? thanks again for all your help.
Old Feb 4, 2002 | 07:01 PM
Aphrodavid's Avatar
if youre still getting code 20, i recommend taking the car to a shop that specializes in electrical automotive stuff. yes the eld sensor is part of the main fuse box. as far as fixing the eld sensor, i really cant help you there as i have never done it myself nor have any of my friends, sorry.
Old Feb 4, 2002 | 08:15 PM
vsual's Avatar
thanks for your recommendation, but that would be my last choice. my father also told me to take it to the shop. i told him i dont want to spend an amount of $$.
i also told my dad about this site and i said i know most people here at honda-tech has all the knowledge and has experience this problem. i'm sure of it they can help me out without spending that much $$.
anyone else that can help me solve this problem??thanks again in advance
Old Feb 6, 2002 | 07:10 PM
vsual's Avatar
i have another question.i spoke with one of the honda mechanic at the dealer and also recommended to try and replace my main fuse box.i forgot to ask him this question but i have a dx and my question is....should i get an original dx engine fuse box or should i get an si one? or are they the same?? just wanted to know before i go to the junkyard and pull one off. tia
Old Feb 13, 2002 | 03:48 AM
vsual's Avatar
i purchase me another underhood fuse box....but i cant get rid of the code20. what other things should i be looking for?
MooG1337
Acura TSX
Oct 7, 2012 05:30 PM
usdm_ED7
Aug 30, 2011 09:30 AM
zccr-xsi
Aug 29, 2005 11:53 AM
Gennady
Jan 28, 2002 11:32 AM
