Coolant Probs....TALK TO ME
Old May 8, 2005 | 05:40 PM
Mr. Wonderful's Avatar
Default Coolant Probs....TALK TO ME
Alright....
the car - 99 cx
the engine - b18b1 (78k)
the problem - coolant level drops after driving
there is absolutly NO smoke coming from my exaust or my gaskets. however there is a very very obvious smell inside the car and under the hood while engine is running. i dont know if the smell is burning gas, oil or coolant, but its there. the coolant in the resevoir will even fall maybe an inch after driving for just a few minutes, maybe 7 miles. it will continue to fall until it reaches just above the "min" line on the resevoir.
i would love to be able to avoid having to tear the engine apart just to see that in fact it was not my head gasket that was causing the problem. Does anybody have any suggestions of what i need to do before i get someone to replace the head gasket ?
it is worth noting that i retained my stock radiator when i did my swap and i haven't seen a single leak under the hood although i will be doing a thorough inspection tonight when i adjust my valves. Thanks fellas.
p.s. - if someone guesses the problem i will paypal you five bucks
Old May 8, 2005 | 05:48 PM
civictildeath's Avatar
Default Re: Coolant Probs....TALK TO ME (djek)
mine drops to above the min line and stays there but i dont have the smell.
the smell of coolant is a sweet smell. you will know it or have a chick smell it. if she says it smells like flowers, its coolant.
im betting its just when under pressure of warm temps, it slips out somewhere little at a time so its unnoticeable.
Old May 8, 2005 | 05:53 PM
TeamNextGenChris's Avatar
have you checked for leaks everywhere?is your carpet wet on the passenger floorboard?
do a leakdown test to see if it is the headgasket.
how old is your radiator cap?when they get old the spring weakens and won't hold pressure anymore.
Chris
Old May 8, 2005 | 06:05 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Coolant Probs....TALK TO ME (TeamNextGenChris)
<u>IT'S PROBABLY YOUR HEATER CORE</u>.
And I don't need money. It's a bitch of a job, though, so I suggest putting the $5 towards some sort of hard alcohol to take the edge off .
Old May 8, 2005 | 06:07 PM
The Internet Tough Guy's Avatar
Default Re: Coolant Probs....TALK TO ME (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote"><u>IT'S PROBABLY YOUR HEATER CORE</u>.</TD></TR></TABLE>
oh noes
that's what i was thinking as well - but it's only a 99. now that it's summer i wouldn't even bother with it. just loop the two hoses together, and spend the three months ripping everything out
Old May 8, 2005 | 06:24 PM
xEnderx's Avatar
Default Re: Coolant Probs....TALK TO ME (The Internet Tough Guy)
Without seeing the car I would hav eto go with "heater core"....and yeah, its a frigging nightmare job.
Don't take it as gospel truth though....keep in mind that we are all just guessing.
Old May 8, 2005 | 06:25 PM
Unceasing Measure
Default Re: Coolant Probs....TALK TO ME (xEnderx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx &raquo;</TD></TR><TR><TD CLASS="quote">Don't take it as gospel truth though....keep in mind that we are all just guessing.</TD></TR></TABLE>
I'm not. I can read minds and see the future.
Old May 8, 2005 | 06:51 PM
Crazysol's Avatar
Mine was doing the same thing and i couldnt find it either. Look at the lines that are to the left of the intake mani. That is where my leak ended up being.
Good Luck. I hope it is something minor like it was for me
Old May 8, 2005 | 07:09 PM
Default Re: Coolant Probs....TALK TO ME (Crazysol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazysol &raquo;</TD></TR><TR><TD CLASS="quote">Look at the lines that are to the left of the intake mani. I hope it is something minor like it was for me</TD></TR></TABLE>
that location is where i have been placing most of my concentration. And thanks for the hope.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">have you checked for leaks everywhere?is your carpet wet on the passenger floorboard?
how old is your radiator cap?when they get old the spring weakens and won't hold pressure anymore.</TD></TR></TABLE>
The floorboard is dry as Hell and my rad cap is stock from 96. Will replace tomorrow. I don't have the first ******* idea what a leakdown test is. Please Please explain. Thank you.
how can i tell if it is my heater core ? And.......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">so I suggest putting the $5 towards some sort of hard alcohol to take the edge off .</TD></TR></TABLE>
always
thanks everyone i hope it ends up being something cheap. Only car to get me to and from school and work
Old May 8, 2005 | 07:16 PM
Unceasing Measure
Also, check the exhaust section right behind the intake manifold (under it, obviously) for signs of white or green residue from coolant falling on it from the intake mani area.
Old May 8, 2005 | 07:27 PM
will do
Old May 8, 2005 | 08:24 PM
bumpo
Old May 8, 2005 | 09:11 PM
bump b4 bed nukkas
Old May 9, 2005 | 01:01 PM
fprunner03's Avatar
do a compression check and see if your loosing compression in any of your cylinders.
Old May 10, 2005 | 06:35 PM
Default Re: Coolant Probs....TALK TO ME (fprunner03)
well well well the problem is fixed *******. i am too embarrased to tell you the reason but lets just say that it was simple. So simple it was overlooked.
Old May 19, 2005 | 09:34 PM
Jeremy D. Swain's Avatar
Clamps are bitches right!
Old May 20, 2005 | 12:45 AM
Morning Call's Avatar
clamps or drain plugs lol
that or his rad cap wasnt on all the way
what else could it be.. hmm yeah clamps.. rad rain.. uhm.... i dono something like that lol
xpdude
28
May 3, 2010 02:33 PM
DennisWaller
Aug 6, 2008 02:33 PM
Morasso
Mar 11, 2007 07:14 PM
ForceXVII
Jun 14, 2003 01:31 PM
sagaprelude
Feb 3, 2002 07:45 AM
