#234 is fug'd?!?
Hmm...From what I recall, you're using the entire stock valvetrain/cams, right? How did you discover this?
Best of luck with the repairs - on the bright side, it seems like a good time for some bigger bumpsticks.
dude, looks like it's on the base circle to me... is that rust? can't tell from the pic. clean it up with a little scotch brite and you're gtg.
D
edit - looked at it again, can't tell if that is on the lobe itself, or the base circle of the cam. more info.
[Modified by D, 12:28 AM 2/4/2002]
D
Bbasso:
I have no idea what happened or what's wrong w/ them. I ran my finger across it and could't feel any extra wear there. After seeing this and getting disgusted, I went out for a couple of hours and came back and finished up the valve adj. Maybe that's why my car was making the pinging like noise?
D:
The #3 cylinder was at TDC, so this is what I saw when I attempted to adj the valves.
y
shi - who just said fug it and also did this
D:
y
Nice look Yoshi!
00-ITR-373: who's referring to the valve cover and not the cam
-I'll be back out to LA soon, get my hood and mirror ready!!
[Modified by 00-ITR-373, 9:33 PM 2/3/2002]
[Modified by 00-ITR-373, 9:34 PM 2/3/2002]
Ohhh, well I hope you have luck and find out that those spot mean nothing... and that the ping soung hopefully just came from bad gas (had a bean burrito
But if anyone else knows whats the problem is here, pls tell all of us so we could be as smart as you!
)But if anyone else knows whats the problem is here, pls tell all of us so we could be as smart as you!
Nice look Yoshi!
y
shi - who at one point got so
, he drilled some holes for the harness and fug'd that up t00!
yoshi,
is that the jdm center console between the seats? if so how do you like having it in there instead of the arm rest one?
OR are my eyes just playing tricks?
[Modified by Bbasso, 12:45 AM 2/4/2002]
yoshi,
j-bot - whos just steady clownin tonite
[Modified by natadekoko, 10:36 PM 2/3/2002]
Hope it's nothing bad Yoshi. Nice valve cover and seat btw. What brand seat is that?
I personally love that seat. That will probably be the one i will get. Looks Bad Azz.
Guest
Posts: n/a
yoshi - who at one point got so
Really Yoshi, I though you knew better............
Yoshi - Who SHOULD get a roll cage for that harness before he hurts himself at the track............
y
shi - who will only use this at the autox for now.
Bbasso:
D:
y
D:
y
Yeah j00 missed it.....we had some g00t laughs at kitkatR's house!
