Need help with a B18A1 swap asap
I have a 92 dx hatch that had a sohc vtec in it but it blew up. So I found a b18a1 motor and ecu for 500. I want to get it but I'm not sure what all I need. I know I need a b series hydro tranny. But what shift linkage,axles and mounts do I use without getting hasport mounts and axles. I need to do this swap as cheap as possible b/c I'm about to have surgery again and I'll be out of work for about 2 months plus I'm getting ready to move. So if anyone can't help me out thanks alot.
Thanks alot,
Chris
Thanks alot,
Chris
Well I just searched and I didn't find the info I need to do the swap. We are here to help eachother not too just tell them to search. I don't have the time to waste so I want someone that was doen the swap too help me so I can do it right the first time
Thanks Chris
Thanks Chris
Any 94+ teg manual linkage
obd1 LS ecu, DX ecu may also work
94+ teg axles
Some teg mounts.
Its basically the same thing as any dohc vtec swap. You need the same parts except the vtec ones.
94+ teg axles
Some teg mounts.
i think u need the obd1 ls engine harness. i did a 00 gsr swap into my 92 civic i know i used the whole engine harness from the gsr motor it plug right up into my engine bay. u can use your dx ecu just redline will be lower so i would swap for a obd1 ls ecu. mounts ? i honestly forget im pretty sure i used booth mounts that were on the motor driver side and mount on top of tranny the rear mount was my stock civic one. and im not sure about the front tranny mount. i didnt bolt that up (lazy
im going to be doing the same swap obd0 b18a1 into a 92 cx so i would also like to know for sure about the engine harness. Oh dude your going to need a obd1 distributor and alternator.. depends on what yr b18 if u got a 93 your obd1 90-92 you got a obd0 like me and gotta swap the dist and alt. and injectors too i think.. (upgrade em
quick1.6
15
Feb 13, 2010 08:16 PM
EJ8CIVIC
Aug 29, 2006 02:18 PM
jdm1994hatch
Mar 24, 2006 09:53 AM
