Correct P.S.I
Old May 8, 2005 | 08:15 AM
systemoverload's Avatar
Default Correct P.S.I
What is the correct PSI for daily driving on 16s-- 205 46 16
Old May 8, 2005 | 08:29 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Correct P.S.I (systemoverload)
It depends on the car and the tire.
As a general rule, your best bet is to start with the tire pressure recommended by the CAR'S manufacturer (in the owner's manual and/or marked on the car's glove compartment, door jamb, etc). Then adjust upwards or downwards from there based on handling, tire wear, etc.
Recommendations are for COLD tire pressure (i.e. measured when the car has been sitting in the shade for at least a couple of hours). Don't forget that ambient temperature has an effect on tire pressure; every ten degree rise in temperature adds about 1 psi. So you can adjust for that if you measure pressure at a time when the temperature of the area where the car is is more or less than the temperature at the times you normally drive the car.
Old May 12, 2005 | 05:43 PM
wannabe_si's Avatar
Default Re: Correct P.S.I (nsxtasy)
yup just use what it says for stock
benji7288
Nov 21, 2007 01:21 PM
SkRiBLaH
10
Feb 16, 2004 09:25 AM
Twigster311
Aug 10, 2003 05:31 PM
PoonHunter
Jul 14, 2003 11:39 AM
MooreBoost
Sep 5, 2002 03:26 PM
