gsr cluster swap (searched)
Old May 8, 2005 | 04:44 AM
VegaS10's Avatar
Default gsr cluster swap (searched)
On a 89 crx si, where do I get vss from?
Using some of my resources (I'm an installer), I found there is a yellow/red wire, high int he driver kick panel for vss. Would that work for the gsr cluster?
If not, where do i find vss or how/what do i need to *** it to my 89 crx si?
Alot/all of the wiring info I've found for the swap pertains to 90-91's.
Thanks in advance for any and all help.
Old May 8, 2005 | 04:34 PM
VegaS10's Avatar
Default Re: gsr cluster swap (VegaS10)
ttt
Old May 8, 2005 | 06:36 PM
B18 CYA's Avatar
you need to get a electronic vss from an integra in order for it to work because the crx uses a cable speedo...i just put one in my 91 dx, but i have a gsr swap so you just splice in the wire...
rigo1224
Jul 28, 2011 06:16 AM
xpwex
15
Dec 5, 2010 07:29 PM
NRanella
Sep 22, 2008 06:27 PM
crx_gsr_vtec
Nov 6, 2006 09:07 AM
LudeJdm
Jul 3, 2005 09:10 PM
