A little help here BREATHER BOX / S1 J1 CABLE TRANNY
I was woundering if anybody that has a full track car was using that little breather box on the back of the motor and whats its real purpose .Is it smog or do i really need it. You know the one the one that comes from the back of the block to the intake manifold. Also has anybody had one of the b series trannys rebuilt j1 or s1 sinkcros cable tranny Iam out here in Cali thanks in advance.
I am using one on my drag car.. Its just a box that allows oil that comes up with the crankcase pressure to be drained back into the engine.. Its basically a catch-can.. I just removed the pcv valve and left everything else there..
I rebuilt my YS1 cable tranny with new syncros, what do you want to know about the process?
I got a little more info on what to use for the syncros but i dont know how true or correct it is . I heard you can use 90 ls integ syncros what do you think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedevil »</TD></TR><TR><TD CLASS="quote">I got a little more info on what to use for the syncros but i dont know how true or correct it is . I heard you can use 90 ls integ syncros what do you think</TD></TR></TABLE>
I think you should call Gear-speed and get a set of their carbon coated syncros for like $100 shipped..
http://www.gear-speed.com/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedevil »</TD></TR><TR><TD CLASS="quote">Tgreaves bluedevil thanks you .</TD></TR></TABLE>
bluedevil Tgreaves says your welcome..
