micropolish crank decision
Old May 7, 2005 | 07:55 PM
mrDFWmechanic's Avatar
Default micropolish crank decision
i'm in the middle of fully building a motor for turbo, i want to get the bottom end balanced and the crankshaft micropolished. i can take the crank to a local shop and have it micropolished ( which i have no clue how much thats gonna cost ) or i can order one from autozone, where i work please dont flame. the one from autozone is from the company HI-TECH, and its 112.00 for a rebuilt one thats been micropolished and everything. so should i let a shop do the work, or do i order the reman. one from my work.
Old May 7, 2005 | 08:34 PM
bump because i need an answer
Old May 7, 2005 | 08:35 PM
LSVTEC 91 Civic's Avatar
Banned
I wouldn't trust an Autozone product... Might wanna take that crank to a reputable machine shop for a balance and a micropolish.
murtnabila's Avatar
Default Re: micropolish crank decision (iROCKtheSOHC)
Let the shop polish it. I don't know about the autozone one, but the stock ones are damn strong.
Old May 7, 2005 | 08:43 PM
the block had around 100,000 on it when me and the friends pulled it apart, plus i called endyn to wonder just how much it is to balance a crank and they said 250. thats not including micropolishing. i'm gonna call the company next time when i work and get the real deal on the crankshaft.
Old May 7, 2005 | 08:44 PM
keep in mind my goal is over 500 with this motor so i'm doing this just for insurance.
Old May 7, 2005 | 08:55 PM
B18C1CYA's Avatar
i would saty away from the zone one , and get the stock one polished
Old May 8, 2005 | 01:28 PM
NJIN BUILDR's Avatar
The autozne (HI-Tech) is going to be ground undersize and will only be factory balanced.The oem heat treat (nitriding) will be mostly ground away.Micropolish will run around $25 plus the cost of cleaning it.Reuse your crank if it is not damaged.Balancing a honda crankshaft takes about 15 minutes if your really slow.That means about $1000/hour to balance a crank.Sounds a little high to me.
Glenn
Old May 8, 2005 | 08:01 PM
i believe endyn said like 250 to just balance it. i could be wrong
Old May 8, 2005 | 10:39 PM
biotech0123's Avatar
Default Re: (iROCKtheSOHC)
Whatever Endyn tells you its going to be gold, he may balance the crank but if the jouranls look good then he wont polish them simply because it will throw the bearing codes right out the window
Old May 9, 2005 | 09:14 AM
Steve91's Avatar
I would be weary of the Autozone crank because its probably been turned (i.e. undercut journals) which require thicker bearings. You never want that crap in a hi-po motor.
Old May 9, 2005 | 11:00 AM
PrettyLude's Avatar
earl does micropolishing and balancing too
Old May 9, 2005 | 11:28 AM
i want a local shop to do this not somewhere in cali
Mostecstreethb
Feb 22, 2007 05:20 AM
Mostecstreethb
Feb 21, 2007 07:48 AM
BeerMan
Sep 27, 2004 11:51 AM
Greyout
Jun 17, 2003 10:41 PM
int3gra
Jun 3, 2002 02:48 PM
