OBD0 to OBD1 q's
Old May 7, 2005 | 05:50 PM
alleyezonme's Avatar
Default OBD0 to OBD1 q's
Hey my buddy is looking to go from an OBD0 to an OBD 1. he has a b16. What dizzy can we use? i have a 92 civic cx dizzy( OBD1) is that good enough or do we need something else? We searched and couldn't really find the specifics on the dizzy
thanks
Old May 7, 2005 | 06:27 PM
dxisonlyabadge's Avatar
Default Re: OBD0 to OBD1 q's (alleyezonme)
if hes going obd1comp, use obd1 dizzy
Old May 8, 2005 | 01:02 AM
Default Re: OBD0 to OBD1 q's (dxisonlyabadge)
any OBD 1 dizzy??
Old May 8, 2005 | 06:52 AM
slywfbpsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alleyezonme &raquo;</TD></TR><TR><TD CLASS="quote">any OBD 1 dizzy??</TD></TR></TABLE>yeah basically, I looked up a d16z6 dizzy and a b16 del sol dizzy from autozone, and both had the same part number.
Old May 8, 2005 | 11:12 AM
toxicshit's Avatar
Default Re: OBD0 to OBD1 q's (slywfbpsi)
not all the Dizzys fit the HEAD.
we used an Delsol VTI VTEC dizzy that came on a B16A2 engine with a P30 ecu
and that fitted nicely the Delsol ESI SOHC Vtec dizzy wont fit the Head.
Old May 8, 2005 | 11:28 AM
ICeDoUt's Avatar
Default Re: OBD0 to OBD1 q's (toxicshit)
well how about a d15 dizzy? which is what is on his old motor
Old May 8, 2005 | 12:26 PM
96-EJ6 B18C's Avatar
Default Re: OBD0 to OBD1 q's (ICeDoUt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICeDoUt &raquo;</TD></TR><TR><TD CLASS="quote">well how about a d15 dizzy? which is what is on his old motor</TD></TR></TABLE>
Nope, it has to be either OBDI or OBDII. I would just get the OBDI B16 one, it will bolt right up.
Old May 8, 2005 | 12:47 PM
Mr_CRX's Avatar
Default Re: OBD0 to OBD1 q's (96-EJ6 B18C)
Get an obd1 distributor for a B-series VTEC motor. Other distributors may "work" but you usually have to either cut one leg off or enlarge the bolt holes or something along those lines.
Old May 8, 2005 | 01:02 PM
ICeDoUt's Avatar
Default Re: OBD0 to OBD1 q's (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">Nope, it has to be either OBDI or OBDII. I would just get the OBDI B16 one, it will bolt right up. </TD></TR></TABLE>
The d15 is obd1 unless my friend can't read his motor code right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Get an obd1 distributor for a B-series VTEC motor. Other distributors may "work" but you usually have to either cut one leg off or enlarge the bolt holes or something along those lines. </TD></TR></TABLE>
Well i have access to one that i would just steal form my friend so i wouldn't mind cutting a leg off, thats what my current setup is anyway, i am using an HF dizzy on my b16.
Old May 9, 2005 | 01:19 PM
ICeDoUt's Avatar
anyone ever go out on a limb and try the cheaper way???
Old May 9, 2005 | 01:31 PM
user 98292739's Avatar
yes your friends car is a OBD 1 car....but dont quote me on this one...but i thought there were differences between non vtec dizzys and vtec dizzys. even on distributor king its all labeld differently. but for some reason i dont think yours will work because it is a D motor not a B motor...but i could be wrong...
Old May 9, 2005 | 02:22 PM
ICeDoUt's Avatar
Default Re: (LoCoReX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LoCoReX &raquo;</TD></TR><TR><TD CLASS="quote">yes your friends car is a OBD 1 car....but dont quote me on this one...but i thought there were differences between non vtec dizzys and vtec dizzys. even on distributor king its all labeld differently. but for some reason i dont think yours will work because it is a D motor not a B motor...but i could be wrong...</TD></TR></TABLE>
Point taken, except that for my obd0 b16 i used my hf distributor because the one that came with the motor was acting up. It worked perfectly, i just had to cut a leg off, and that was off an HF motor. sooo i am leaning towards yea it'll work, but we'll see
Old May 9, 2005 | 03:37 PM
mind as well go try it out "shouldnt" hurt anything disclaimer
Old May 12, 2005 | 02:25 PM
ICeDoUt's Avatar
i guess we'll see this weekend, test fit it and what not
Old May 12, 2005 | 04:46 PM
Rywire's Avatar
B series and D series dizzys are different...
Old May 12, 2005 | 05:22 PM
ICeDoUt's Avatar
Default Re: OBD0 to OBD1 q's (droppedcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">B series and D series dizzys are different...</TD></TR></TABLE>
So then how was my 90 crx hf dizzy powering my b16?
Old May 12, 2005 | 05:55 PM
Rywire's Avatar
Trust me there different.
Are you saying that it bolted up PERFECT, and ran like STOCK?
Old May 12, 2005 | 06:53 PM
ICeDoUt's Avatar
did u read this thread?? i had to cut one of the legs off the d series dizzy for it to work on my b16, and yes it runs like stock. U have to do the same with an LS dizzy, so whats the big deal, i am askin if anyone has used a d series obd1 dizzy when converting to obd1
Seto-Initial-B
Feb 14, 2008 08:06 AM
aarontrini85
May 31, 2007 01:18 PM
civicracer94
Dec 8, 2006 01:28 AM
efrex
Jan 22, 2006 05:39 PM
kingkong
May 9, 2005 11:19 PM
