Need filter for 4" turbo, uni-filter?
Old May 7, 2005 | 04:30 PM
BoOsTiN Dc2's Avatar
Default Need filter for 4" turbo, uni-filter?
I am in need of a 4" filter for my t3/t67, i bought a k&N rd1450 and it doesnt fit because i don't have enough room for my 95 teg with lovefab mini-me t3/t67. Does anyone have more info on the uni-filter? Is it a actual filter or just a foam screen u clamp onto the turbo? Also what else you recommend? I will try to get pictures up tonight or so.
Old May 7, 2005 | 07:53 PM
USDM 4G VTEC's Avatar
Default Re: Need filter for 4" turbo, uni-filter? (tRaCeBuStAbUsTeR)
RD-1400 4 in (102 mm) 7 in (178 mm) 6 in (152 mm) Metal 0.625 in (16 mm) 0 degrees 0 in (0 mm)
RD-1450 4 in (102 mm) 7 in (178 mm) 6 in (152 mm) Rubber 1 in (25 mm) 0 degrees 0 in (0 mm)
RD-1410 4 in (102 mm) 7 in (178 mm) 8 in (203 mm) Metal 0.625 in (16 mm) 0 degrees 0 in (0 mm)
RD-1460 4 in (102 mm) 7 in (178 mm) 9 in (229 mm) Rubber 1 in (25 mm) 0 degrees 0 in (0 mm)
41-1400 4 in (102 mm) 7 in (178 mm) 18 in (457 mm) Metal 0.625 in (16 mm) 0 degrees 0 in (0 mm)
from KN filter website
http://www.knfilters.com/search/univround.aspx
Old May 7, 2005 | 08:35 PM
Default Re: Need filter for 4" turbo, uni-filter? (USDM 4G VTEC)
yeah i got the rd1450 its too big. I need something smaller. A lot smaller
velisma
Feb 13, 2010 10:36 PM
the.hamburglar
Oct 14, 2006 11:17 AM
RedR
Feb 8, 2006 06:13 AM
dan_w_82
Jan 31, 2005 06:44 PM
DA-MAX
Feb 3, 2004 08:12 PM
