what size turbo do u guys have on your stock gsr motor
Old May 7, 2005 | 02:08 PM
redlseg's Avatar
Default what size turbo do u guys have on your stock gsr motor
whats size turbo do u guys have and how much hp are u putting out? also at what psi do u have it set at?
Old May 7, 2005 | 04:14 PM
redlseg's Avatar
Default Re: what size turbo do u guys have on your stock gsr motor (95gsrhatch)
i just got rid of my garrett 42/.48 a/r and i need some help on picking a good turbo for my gsr. anyone boostin there stock gsr???
Old May 7, 2005 | 04:39 PM
lean's Avatar
garrett t3t4 .60/.48 a/r
low boost is 8-9, high is 11.
11 put 250 to the wheels tuned on s200b hondata with a mustang dyno. stock engine with arp head bolts.
Old May 7, 2005 | 04:40 PM
1158's Avatar
What are your goals? How much power do you want? You need to give more info if you want to get help. Is this your daily driver or a "toy". I would also suggest using the search feature. There are plenty of posts (especially archived) about gsr turbos.
Old May 7, 2005 | 04:52 PM
redlseg's Avatar
Default Re: what size turbo do u guys have on your stock gsr motor (1158)
well i'm looking to at least reach 280-300hp. its going to be my daily driver. well i'll check out some posts. but i still want to find out what size turbos u guys are running on your gsr. if u can please continue to post here on my thread with your turbo sizes.
Old May 7, 2005 | 05:25 PM
redlseg's Avatar
alright did some searches would a 60-1 do the job. also if i'm daily driving the car would 280-300 hp be safe to drive around in with the stock block?
Old May 7, 2005 | 05:45 PM
BlueShadow's Avatar
I think if you never plan on going over 300 HP then IMO the 60-1 is going to be overkill. Have you thought about the GT28RS or a GT2871R? They'll be a little more expensive, but the response and powerband would make up for it.
Old May 7, 2005 | 05:57 PM
redlseg's Avatar
Default Re: what size turbo do u guys have on your stock gsr motor (BlueShadow)
yea i was looking at the gt series turbos but there way to expensive for me.
Old May 7, 2005 | 06:05 PM
1158's Avatar
Take a look at the either the GT3251E or the GT3255E. Both will have great spool up, will be able to support boost until redline and can be found at a decent price (because they do not have a BB center section). I have been doing research for quite sometime, almost 3 years, on a turbo setup for my GSR and I think I'm going to go with the GT3251E. My goals are around 300 whp and should be able to reach this at 12 to 14 psi.
Here is the compressor map for the GT32E
Old May 7, 2005 | 06:10 PM
BlueShadow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95gsrhatch &raquo;</TD></TR><TR><TD CLASS="quote">yea i was looking at the gt series turbos but there way to expensive for me.</TD></TR></TABLE>
What prices have you seen for the 60-1? if the GT28RS is too much you can look at the GT28R which is only $775. I dont know how the GT28R compares to the 60-1 or the 28RS and 2871R. A few weeks ago I did some searching for 60-1 on H-T, but that wouldn't come up in any of the terms I typed in. Just check and make sure that you aren't getting a turbo that is too big for you intended goal. Maybe somebody can tell you whatthe spool times are gonna be like, because I dunno.
Old May 7, 2005 | 06:12 PM
Bimmerman's Avatar
GT28RS
Old May 7, 2005 | 06:23 PM
1158's Avatar
Default Re: what size turbo do u guys have on your stock gsr motor (Bimmerman)
I would be worried the GT28RS might run out of steam up top. I took a look at the 28RS but the top end was what sent me to the GT32. I could be wrong as this will be my first turbo. Talk to Art (arturbo) he helped me out.
Old May 7, 2005 | 06:28 PM
BlueShadow's Avatar
Another person to talk to would be tony the tiger. I remember watching that video of the Green Teg GSR with the GT28RS, and I thought it was pretty cool.
Old May 7, 2005 | 06:32 PM
Bimmerman's Avatar
check out http://www.atpturbo.com they had a A4 with a GT28RS turbo making 426 all wheel HP , and AWD have a 35% drive train loss of power.
t3/t4 vs gt28rs on 2nd gen teg
Old May 7, 2005 | 06:33 PM
1158's Avatar
Yeah, I saw that vid...it was awesome. That's what made me want the 28RS initially. On Precision's site the 28 is listed at 320 hp. I realize that precision underrates their turbos, but that is also hp at the crank and not whp. If I were to want more power later I don't know if the 28 would be enough.
Here's the thread...https://honda-tech.com/zerothread?id=1027496
Modified by 1158 at 2:10 AM 5/8/2005
Old May 7, 2005 | 08:44 PM
z6's Avatar
z6
gt32
Old May 7, 2005 | 08:58 PM
B18Flip's Avatar
Default Re: (z6)
i had a gt32E on my stock gsr... 285whp @ 8psi and reached 8psi around 3600k. I loved the turbo
Old May 7, 2005 | 09:06 PM
a1320addict's Avatar
Default Re: (B18Flip)
running a gt28r with avo compressor housing...made 246 to the wheels at 8 psi...
full boost is at around 3100
Old May 7, 2005 | 09:21 PM
1158's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">i had a gt32E on my stock gsr... 285whp @ 8psi and reached 8psi around 3600k. I loved the turbo </TD></TR></TABLE>
This is the turbo that I am probably going to go with. If you don't mind, what was your setup? I have just started to get the things I need to piece together a kit. I am hoping for around 300 at the wheels. I figure 10 to 12 psi should do it. What fuel/engine management were you using?
Old May 7, 2005 | 09:50 PM
redlseg's Avatar
down here in tx i can get a new 60-1 for 475+tax
but the gt28rs is killing me on the price.
Old May 7, 2005 | 10:05 PM
redlseg's Avatar
how much hp do i have to have in order for the 60-1 to work to its full potental
Old May 7, 2005 | 10:37 PM
98gsrTEG's Avatar
gt30r 10 psi head never been off the block, 314whp on dyno jet
stock throttle body, log mani, stock intake manifold tuned with greddy emanage
Old May 7, 2005 | 11:19 PM
DRIVENRacing's Avatar
gt30 is definatelly worht the money.. i must say im impressed with spool time, and instant power... but sc61 would do the job for 300 whp on stock motor easy on 10 psi ish on a conservative tune gl...
Old May 7, 2005 | 11:20 PM
dthrone's Avatar
Default Re: what size turbo do u guys have on your stock gsr motor (98gsrTEG)
Garrett T3/TO4E turbocharger .60 trim!
250whp @6.5 psi (2.25 inch exhaust)
Old May 8, 2005 | 01:14 AM
hotrex's Avatar
Default Re: what size turbo do u guys have on your stock gsr motor ("SPANKY")
i made 319.9 hp at 9 psi with a t3/to4e 60 trim.
at 12 psi the 60 trim is right in the meat of its efficiency range on a b18c1 according to its compressor map.
