help with wiring..can i just swap harnesses
ok i got an 89 dx where the owner attempted a mpfi swap with a d16a6 and they just screwed everything up so can i just swap over my 89 crx hf wiring harness the only extra plug i noticed was a square one by the pass. strut tower....thanks and yes i did search.
oh and with the 89 dx harness that i attempted to fix well the starter was bad, it would just click when you try and start it so i just swapped starters and now i get solid cel and solid ecu light which means bad ecu so do you think it fried the ecu or could it be a wiring problem causing it to do this?
swapping a different harness is a lot of work, but you could get an 89 dx harness and start over, it'd plug in.
take this with a grain of salt, but what i think happened is the wiring killed the ecu. theres other possibilities, but that's what i think. don't just put a different ecu in, because the same thing could happen.
i fixed thanks anyways, just needed to redo some ground wires but the whole dpfi to mpfi wiring was all wrong the kid must have been a huge retard.
well he may be a retard. now he is going to run to his friends and tell them how easy it is to do a motor swap. now he is going to come on here and give advice on how he did the wiring swap.
