OIL PUMP info and wtb
Old May 7, 2005 | 09:03 AM
swaytec360's Avatar
Default OIL PUMP info and wtb
My build is almost finished and i need an oil pump i was going to run a vaccum pump but my machine shop says external oil pump with vac dry sump is $$ looking for wet sump external he says to get daily, peterson, or barnes what do you guys think
portflow gsr head
rocket m24 cams
supertech valvetrain
twmitbs52mm
ls block 85mm sleeved
cp gasported 85mm 14.1 cr
eagle rods
calico coated acls
dtr 2.0l header
Old May 7, 2005 | 09:36 AM
earl's Avatar
Default Re: OIL PUMP info and wtb (swaytec360)
http://www.pauter.com/centerflo_pumps.htm
Pauter makes an external oil pump
Old May 8, 2005 | 06:06 AM
HR-1320's Avatar
Default Re: OIL PUMP info and wtb (earl)
The barnes pumps I have are very nice. Beware of pumps that mount on back of motor they can get tricky to work on , its a little tight.
Old Oct 8, 2005 | 11:18 AM
h22 civic's Avatar
hmmm never knew they made these,pauter oil pumps anyone use them? if so how are they?also priceing
Old Oct 8, 2005 | 12:23 PM
sa594's Avatar
Default Re: OIL PUMP info and wtb (h22 civic)
Try calling Peterson Fluids and ask for Ronnie. He's very helpful and gives good support
Old Oct 8, 2005 | 02:15 PM
choiboiracing's Avatar
Default Re: OIL PUMP info and wtb (sa594)
my thoughts also????? is it worth it to save like 5K for dry sump or got with the wet sump.
BlUAc
Aug 6, 2007 09:04 PM
Serdar
Oct 12, 2005 12:10 AM
