What trannys will work on a ZC?
Old May 7, 2005 | 07:42 AM
drewboy's Avatar
Default What trannys will work on a ZC?
I just picked up a crx with ZC swap, the tranny wont shift into any gear unless the car is shut off and you turn the car on and take off in that gear.
Since Im new to d-series ZC motors, what tranny will work with the ZC motor? I have one from a d15 but it looks to be hydro as it has a slave cylinder on the front of it.
Also how in the world do I got the axle nut off the hub!!! Its stuck like god knows what!
Old May 7, 2005 | 08:38 AM
EvolDead's Avatar
Default Re: What trannys will work on a ZC? (drewboy)
im pretty sure all d series cable trannys will work.As for the axle nut youll have to get a chisel and hammer and bend the tabs back up.
Old May 7, 2005 | 09:59 AM
bagpipe goatee's Avatar
well, yes all d series that's 88 and up.
but after the ed's, it went from cable clutch to hydraulic, and the mounts on the tranny are different too, so you don't want to use one of those.
so, use an 88-91 d series tranny, and which one you want depends on your desired performance.
if you're not making a hybrid tranny, use an si or a zc tranny. dx's are ok. do not use a std or an hf tranny, if you want any kinds of performance.
Old May 7, 2005 | 04:18 PM
drewboy's Avatar
awesome thanks guys. What tranny is preferred for the ZC? I assume a Si cable tranny? I dorve the car around in 3rd gear today and the motor pulls strong with a pm6 ecu and 87 octane!
Im not sure as to what trany is in there right now
jdmeg6bswap
11
Jul 27, 2010 01:22 PM
JDMister_EF9
Feb 13, 2007 11:48 AM
Gen4Si
Feb 21, 2005 03:34 AM
BaGGed HoNDa
Jul 10, 2004 04:12 PM
M_L_H
May 24, 2004 04:24 PM
