Advice on 89 EF Swap!!
Old May 7, 2005 | 05:44 AM
All-Motor-Freak's Avatar
Default Advice on 89 EF Swap!!
I have an 89 Ef Hatch that i paid $300 im lookin to do a DOHC V-TECH swap or a 1.6 Mugen Motor for $300. Not sure whitch motor to go wit also i can find ne good sites or places that have a decent price for the vtech motors so if u kno where i can find a good price for 1 plz let me kno also Thanxz!! Heres the setups i had in plan: (Also Not Daily Driver Straight Track Use)
B18C
T3/T4 Hybrid Turbo or BIGGER (Not sure wat size)
Fmic Front mount
Cp Pistons
Head Work
Web Cam Shaft
Aem Cam gears
LSD TRANNY
Spoon Valves
B & M Fuel pressure regulator
Edlebrock Victor X intake manifold
75 Shot of nitrous
Eagle Rods
Prospec Head Studs
Hondata
Competition traction/ Bar
Stage 3 Clutch??
MSD Setup
B16A1
Same Setup as Above
(Bigger shot of Nos)
?? Mugen Motor ??
NOT SURE WAT TO DO WIT IT
(PROB SUPERCHARGE)?????
Old May 7, 2005 | 06:18 AM
teknohatchie91's Avatar
Default Re: Advice on 89 EF Swap!! (All-Motor-Freak)
hey buddy it's vtec
Old May 7, 2005 | 08:56 AM
crxtreme89h's Avatar
Default Re: Advice on 89 EF Swap!! (teknohatchie91)
http://www.hmotorsonline.com
No need to look any further.
Old May 7, 2005 | 10:10 AM
boosted_hatch_216's Avatar
have you searched about anything? with the hondata you dont need a fpr. and fmic=front mount intercooler.
the t3/t4 you can get in different sizes
id go with srp pistons, theyre cheaper or you could just do an eagle rotating assembly for like 1400 (new crank rods and pistons)
what kind of head work are you thinkin? 3 angel valve job porting and polishing? you dont need to worry too much about the port and polish. with a turbo itll force the air through the head anyway. maybe gasket match and port match. and get a bigger throttle body and port match everything.
the cam gears are really looks and allow you to adjust your timing. but with hondata you can do this through the ecu so save your self the money.
you can do a rev valvetrain for 450 buck and probably rev to about 9k. (not positive on that number)
port your stock intake manifold
six puck clutch for about $250
Old May 7, 2005 | 10:18 AM
89Si's Avatar
Default Re: Advice on 89 EF Swap!! (boosted_hatch_216)
hahaha <----useless post, callin myself out
Old May 7, 2005 | 10:32 AM
Default Re: Advice on 89 EF Swap!! (89Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89Si &raquo;</TD></TR><TR><TD CLASS="quote">hahaha &lt;----useless post, callin myself out</TD></TR></TABLE>
then why'd you post?
Old May 7, 2005 | 01:08 PM
rsca_crx's Avatar
i don't want to sound like a deterrant, cause people getting into cars is awesome, but hold off for a little bit and do some reading/talking to people to get a better plan. if that second $300 wasn't a typo from 3000, then you really need to evaluate your budget. if it was 3k, you still need to take a look at things, and realize you are talking about a ~$8000 motor that requires a lot of work and tuning before you will be happy with it. i'm sure people will chime in w/ "i did it for x$", but as someone who doesn't know how to build a motor, that is what you are looking at. figure out what you REALLY have to spend, do some researching since about a bajillion people have done this before, and make a plan that makes sense with your budget and goals. good luck
STLEFsi
12
Mar 27, 2014 06:18 PM
JoshinEF
10
Nov 24, 2009 02:30 PM
7andaswitchblade
Dec 3, 2006 07:56 PM
