miss firing
Old May 7, 2005 | 03:08 AM
george34's Avatar
Default miss firing
the car is an stock 88 CRX si and i don't own the car but am thinking of buying it. the guy said when the car comes up to operating temp. that it then miss fires. he also said the exhaust is not connected to the header. what could be the problem?
Old May 7, 2005 | 08:32 AM
bagpipe goatee's Avatar
well, you kinda answered your problem.
when i drove with no exhaust on the car, it backfired a lot.
you kinda need exhaust backpressure, because otherwise the exhaust valves will overheat and cause damage.
granted, it could be other things causing the missing, like plugs, etc, but i'd bet that.
Old May 7, 2005 | 08:34 AM
SiR Inspired ED7's Avatar
Default Re: miss firing (george34)
Check Spark Plugs & Wires
Old May 7, 2005 | 10:19 AM
george34's Avatar
Default Re: miss firing (88 Crx Si)
so what ever it is can be fixed easily
Old May 7, 2005 | 10:22 AM
boosted_hatch_216's Avatar
most likely and if there is a problem the stock motor can be had for cheap. if the price is right then id buy it.
Special_K26
Jun 2, 2013 03:33 AM
TheDonut
14
Jun 9, 2012 11:45 AM
crx90rcr
Jan 9, 2006 08:48 PM
sykotic
Sep 7, 2004 05:30 PM
BMac86
94
Dec 26, 2003 08:23 PM
