B16 header
Old May 7, 2005 | 12:20 AM
nsmB16's Avatar
Default B16 header
Ive got a b16 in a crx. Anyone know if a 4-1 header that says as individual tubes past the cross member will fit? It seems like a tight fit between my block and my cross member and im not sure if this new header will fit. Id find out for my self, but i don't have the tools at my new house and im not going to pay a mechanic to tell me i need a new header. Thank you
Old May 7, 2005 | 05:38 AM
Ruthless671's Avatar
Default Re: B16 header (nsmB16)
it will fit, you will have to unbolt your crossmember and probably shave the crossmember a bit to fit when after you install the header. good luck with the install
Old May 7, 2005 | 11:36 AM
nsmB16's Avatar
Default Re: B16 header (Ruthless801)
Yeah i was really hoping i could squeeze it in there without notching the cross member, but what can ya do. Im not buying a new header so ill have to deal with it. Do you know how much i can shave without hurting the strength of the cross member?
Old May 7, 2005 | 11:58 AM
RCautoworks's Avatar
Nope, a 4-1 header will not fit. You will either have to cut the crossmember which with the right tools its not hard ( look for someone in your area that will do it, I know if you were around my area, I would do it for cheap )
dinko
Jun 25, 2007 10:01 AM
blk_eg4
Jun 17, 2007 05:19 PM
K.Quinn
Jun 22, 2006 10:39 AM
JDM00SI
Aug 30, 2005 10:22 AM
