EG front wheel hub replacement
Old May 6, 2005 | 06:17 PM
13BT's Avatar
Default EG front wheel hub replacement
the passenger wheel bearing in my 1994 Civic CX is shot. I have a friend with a EG parts car at his place and i was wondering if i can swap the front hubs to my vehicle to serve as a TEMPORARy replacement. I believe his car was said to be a VX.
Now, if this will be a go, can someone go about and explain to me on how to remove it? I have a helms manual downloaded but the computer it was on crashed.
Old May 6, 2005 | 06:38 PM
TeamNextGenChris's Avatar
Default Re: EG front wheel hub replacement (13BT)
it will work.
remove the caliper(two bolts),remove the axle from the hub,and unbolt the steering tie-rod,and upper and lower ball-joints from the spindle on both cars.this will aloow the spindles to be removed.just swap int he new one and put it all back together.
Chris
freestyle addict
Aug 30, 2007 08:47 AM
Grip
Jul 24, 2004 01:10 PM
H23vtecEG
18
Feb 2, 2003 05:23 PM
